moved to power supplies section
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7836496
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7836518
11 minutes ago, Divine_ said:
Is there anything wrong with this PSU? http://pcpartpicker.com/product/kbBv6h/nzxt-power-supply-v2550w and re there recommendations for a PSU around this price that's equal or better performance wise? (If there IS a downside to this PSU)
a-ok
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7837190
It's a High Power / Sirtec / Sirfa Element Smart unit internally. I would take a past on that unit and get the CX550M instead or spend a little more for the EVGA Supernova 550w GS / G2 or Corsair RM550x.
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7837269
http://pcpartpicker.com/product/TgW9TW/seasonic-power-supply-m12ii520bronze Much better internal quality, fully modular and around the same price.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7837300
5 minutes ago, lee32uk said:
Actually it isn't that good.
I used it, it worked fine
My Main PC:
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7837555
Not how you tell whether a PSU is good or not dude.
4 hours ago, Divine_ said:
I was wondering if there are any recommendations for modular PSU's that are equal or slightly better than this on : http://pcpartpicker.com/product/TgW9TW/seasonic-power-supply-m12ii520bronze I found this one, but it's not modular
That´s modular?
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7837654
1 hour ago, lee32uk said:
And that makes it a good unit does it ?
I used the psu for well over a year and never had any problems and it ran in a high performing machine, it is a good psu. Theres nothing proving against this.
My Main PC:
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7837829
Just because it worked for you doesn't mean it's top of the line. Lots of people use CX power supplies and it's well known that they're not top of the line.  Any site that does tests on over current protection, ripple suppression, etc. will be able to actually objectively confirm or refute claims that your PSU is "good".  I don't have said links, but maybe someone else does...
@STRMfrmXMN
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7837837
That´s not how you determine something´s quality. Not only is it unscientific, the thing is $65. I could get the GQ for just $4 more, which is not only Gold rated efficiency, but of much higher quality: http://pcpartpicker.com/product/kz7CmG/evga-power-supply-210gq0650
Or I could get the M12ll from Seasonic, which is cheaper, and of much better quality: http://pcpartpicker.com/product/TgW9TW/seasonic-power-supply-m12ii520bronze
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7837846
@STRMfrmXMN
Already checked. It´s very mediocre. With PSUs like the GQ for $4 more, or the M12ll for about $4 less, not worth it at all.
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7837850
"I've used it for X amount of time, therefor it's good" is the same logic intoxicated people use to justify driving themselves somewhere while under the influence. See that flaw in that logic?
The "green logo" CX series is mediocre quality, best suited to a no GPU system or, say, a 260X+ Athlon system. They're have an ambient temperature tolerance of 30C which is quite low, and although the 3rd revision of them fixed this, they have the same model names so unless the SKU is checked you can pay money for a decent 3rd gen and buy a first gen. The "grey logo" CX is quite good nowadays and I can recommend it, somewhere up to a GTX 970 system.
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7838150
8 minutes ago, STRMfrmXMN said:
*snip*
what about this one: http://pcpartpicker.com/product/kbBv6h/nzxt-power-supply-v2550w
that's the one in question, the CX was just an example I made 9_9
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7838195
Op I have the nzxt hale82 v2 700w and it's a pretty cheap psu, and was told it has cheap internal parts.  If you want a white psu take a loot at this one: https://pcpartpicker.com/product/LgJkcf/seasonic-power-supply-ss750xp2s
My RIG:
CPU: Intel core i7 4790k     Motherboard: Msi krait edition z97      RAM: Crucial Ballistix Sport 16GB      GPU: EVGA GTX 1070 8GB Gaming Black Edition     Case: Thermaltake core v71   Storage: Samsung 850 pro 256gb OS, WD green 2Tb, WD blue 500GB, WD blue 350gb, Segate barracuda 250gb      PSU: NZXT hale82 v2 700w     Cooling: Noctua nh-d15   Operating System: Windows 10 Pro
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7838213
It's pretty mediocre for the money.
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7838388
Here is a review summary of the 700W version that says otherwise.
http://www.techpowerup.com/reviews/NZXT/HALE82-700-V2/11.html
Still think it's a good psu ?
https://linustechtips.com/topic/604740-modular-psu-help/#findComment-7839517
