Blower style is the best for this type of case, since that will move the hot air out, "normal" type of cooler will spread the heat in the system and that is not good for such a cramped pc. So you better get a FE or wait for Asus or gigabyte to make one.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
Don't forget EVGA or PNY; they usually have blower versions as well.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Thanks for the quick response!
Can you show the interior of your case and what fan mount options it has if any?
It may be suitable to add or upgrade the fans in your case to compensate for the heat from the 1070 without needing a blower/reference design cooler on it.  I believe I've heard that the blower coolers are louder and less capable as other coolers and may impact a GPUs performance at higher loads.
You know... In lots of situations, a open air gpu still beats a blower style once you consider temps/noise.
Plus you can always just use a cpu aio.
Personally I think there isn't a good reason to use a blower style cooler anymore.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
they are not that good. The Asus turbo is genius since it can suck air from the back side and the front side, but the asus card itself is kinda meh
In that case a blower will beat the open air.
I'm kinda doubtful...
Open Air coolers still outpreform blowers in the Ncase M1 and that thing has effectively 0 ventilation.
But if any case would  favor blowers, it would be that one...
The N1 also has pretty good airflow, in this case the hot air will just go straight up into the CPU cooler. If the airflow is bad in a case blower is the way to go if it's okay/good go open air.
The M1 has literally no fans, and I've seen results with just a c7 cpu cooler that has blower 980ti's losing.
But ehh the 1070 is lower power consumption than the 970, it probably won't make a big difference either way.
The N1 has literally no fans, and I've seen results with just a c7 cpu cooler that has blower 980ti's losing.
no, but it is a very open case when you compare it to the asus prebuilt case and you can easily get okay airflow in it.
The lower the TDP the better for cases with bad airflow.
Yikes.  That looks really cramped.  Maybe a blower would be a good idea.  I guess it depends on how well those fans cool the interior.
I'm curious though, how is it set up to have the GPU at a 90 degree angle to the motherboard?  Is there some sort of custom adapter?
