Damn i must have set my cooling up right.  Sorry i just had to brag a bit. That is also after 4 hours of playing WoW.
CPU - I5 6600k @4.5ghz, AIO Cooler - H100i GTX, MOBO - MSI Z170 Gaming Pro, RAM - G-Skills Ripjaws V DDR4 2400 mhz, GPU - ASUS Strix GTX 1080, SSD - Samsung 850 Evo 250g, HDD - WD Black 1TB, PSU - Corsair TX 750, Case - Cooler Master Mastercase Pro 5, Monitor - Dell S2716dg 2560x1440 144hz gsnyc  27", AOC I2757FH 1920x1080 75Hz 27", OS - Windows 10 Home.
https://linustechtips.com/topic/604429-gpu-cooling/
wow is more depending on the CPU ;) that might be a cause
and depending if you play on 1080 it shouldnt be much of a problem for the 980
IMO with 27" i'd go for a 1440p display for a better and sharper experience than with 27" low pixel density
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
https://linustechtips.com/topic/604429-gpu-cooling/#findComment-7832900
wow is not a very graphically intensive game...
https://linustechtips.com/topic/604429-gpu-cooling/#findComment-7832906
