HELP!
Go to solution Solved by Sors,
Take the video card out, test if the system boots like that.
Try a different power supply.
Reset CMOS.
My friend has a computer and it is not turning on
the GPU is coming on, nothing else?
HELP!
give us suggestions?
ABOUT ME: Hello, I'm a 15-year-old PC enthusiast. I love helping people with their problems and learning about the hardware of a PC.
DREAM JOBS: Computer Technician, I.T Consultant or a Computer Hardware Engineer.
NEXT BUILD: http://nz.pcpartpicker.com/list/rDXLJV (NOT COMPLETED)
BE NICE TO ONE ANOTHER AND HAVE SOME FUN!
https://linustechtips.com/topic/603923-help/
Check plugs, See if there is a boot error on the MOBO if it has it. Its most the monitor may not be plugged in, unless you have the other components with lights and stuff. We need more information than that
https://linustechtips.com/topic/603923-help/#findComment-7827168
Nothing comes on but the GPU?
The only fans spinning are the GPU ones...
https://linustechtips.com/topic/603923-help/#findComment-7827173
Check that the fans are plugged in. Are theres lights on the motherboard that come on or a little screen with a boot code? Take out ram and reseat it in a different slot and try all sorts of different combinations. Also sometimes a stick or slot isnt working so try with new ram in different slots.
https://linustechtips.com/topic/603923-help/#findComment-7827181
Nothing has turned on (the mobo does not have codes) the only lights to come on is the GPU ones.
https://linustechtips.com/topic/603923-help/#findComment-7827186
