Hello, I've got a problem with my new GPU I received yesterday.
When i want to play GTA V there are lags even while im playing on normal settings.
Maybe my PSU is to weak for it but I'm only a casual and need help :(
CPU: i5-4690
GPU: Asus Readon r9 390x
MBO: MSI B85-G41 PC Mate
RAM: 2x 4GB DDR3
PSU: 600W BeQiuet
https://linustechtips.com/topic/603024-problems-with-the-r390x/
What's your CPU? Did you install the proper drivers?
i7 6700K @ Stock (Yes I know) ~~~ Corsair H80i GT ~~~ GIGABYTE G1 Gaming Z170X Gaming 7 ~~~ G. Skill Ripjaws V 2x8GB DDR4-2800 ~~~ EVGA ACX 3.0 GTX 1080 SC @ 2GHz ~~~ EVGA P2 850W 80+ Platinum ~~~ Samsung 850 EVO 500GB ~~~ Crucial MX200 250GB ~~~ Crucial M500 240GB ~~~ Phanteks Enthoo Luxe
https://linustechtips.com/topic/603024-problems-with-the-r390x/#findComment-7818496
1 minute ago, Fricky said:
Yeah I installed all actual drivers
And you have a 4690K. Did you turn off power efficiency in "AMD Radeon Settings"?
https://linustechtips.com/topic/603024-problems-with-the-r390x/#findComment-7818501
Just now, Fricky said:
The updated from the amd's website
Ok good. Did you turn off the setting in the control panel?
https://linustechtips.com/topic/603024-problems-with-the-r390x/#findComment-7818520
I can't find in the new AMD settings programm but I'm still searching
It should have installed with the driver. Right click anywhere on the desktop, and it should pop up. Go to global settings and turn it off the power efficiency.
https://linustechtips.com/topic/603024-problems-with-the-r390x/#findComment-7818524
2 minutes ago, Fricky said:
So its working a lot better than before, but still got some little frame drops after 5 secs
Do you have MSAA on or something? That murders frames, even a 980 Ti with 8xMSAA at 1080p could go to 45FPS.
https://linustechtips.com/topic/603024-problems-with-the-r390x/#findComment-7818584
Ok now it's working without lags Thanks a lot !!!
No problem.
https://linustechtips.com/topic/603024-problems-with-the-r390x/#findComment-7818601
Hey it's me again ...
after a few minutes it started again and now while im playing Tabletop simulator the GPU usage shows weird things. (Also in GTA)
https://gyazo.com/952f54bd51939126a2c43d2176e3acf3
https://gyazo.com/bffeb4be35e16dbba2c0fcccaf39d7a4
https://linustechtips.com/topic/603024-problems-with-the-r390x/#findComment-7819120
Just go into settings, and enable "Unified GPU monitoring" or something similar to fix usage. It's a bug and until you enable the unified GPU thing, everything GPU usage reports is false. You sure you aren't thermal throttling in GTAV?
https://linustechtips.com/topic/603024-problems-with-the-r390x/#findComment-7819251
I'm now using msi afteburner and enabled it.
The temperature is by 60°C I'll test my card now by using 3D Mark.
https://linustechtips.com/topic/603024-problems-with-the-r390x/#findComment-7819361
Asus so expect crappy firmware (as a fellow Asus owner - it's the damn GPU BIOS)
https://linustechtips.com/topic/603024-problems-with-the-r390x/#findComment-7819702
