Build help/ suggestions
Solved by Starelementpoke,
23 minutes ago, Mastermind said:The goal is mini itx gaming, yes, and I already own the PSU from a previous build, and it is the only 140mm PSU I have atm(the QBX can only house 140mm Max) but will try to look for another one. Any thing else you would change?
If you can wait, might be worth looking into Polaris. The way it´s shaping up right now, you´d be getting a 980ti level card for $250. What case do you plan on using?
