Hello everyone,
I previous made a thread over at Tom's Hardware and I'm none the wiser. You can find the thread and the steps I've covered to try and solve my issue:
http://www.tomshardware.co.uk/answers/id-3071767/system-graphics-card-lag.html#18031392
I was originally running a 670 2GB, i7 3770k and 8GB DDR3 RAM.
Just today, I upgraded to an i7 6700K and 16GB DDR4 RAM. This is prep for a GTX 1080. I am still running my original 670 at the moment. And still running my original Win10 64bit OS on an SSD which has been transferred over to my new system. And I've just performed a clean Nvidia driver install, still no difference.
I am now completely for some reason unable to run games whatsoever. I was getting 45-70 FPS on Overwatch in max settings which is now down to unplayable frames. Same goes for Tomb Raider released in 2014, 40 - 70 FPS down to completely unplayable. It only seems to lag like this when the GPU is under stress, alt+tabbing out of games at this point causes Windows to freeze too.
I've tried new drivers for both my GPU and Board, scanned for viruses/malware and even bitcoin GPU hijacker programs. I'm at a loss.
I think it must be some form of software issue? As if I was running Overwatch on all max settings with the same 670, i7 3770K and 8GB DDR3 RAM. Then surely I can run it with the same 670, i7 6770K and 16GB DDR4 3200MHz
No idea what's up here, anyone else?
Any comments are appreciated.
https://linustechtips.com/topic/602520-same-gpu-upgraded-system-crazy-lag/
2 minutes ago, Narigaur said:
Turn down the settings, then.
Same result. Windowed mode and the lowest settings achieve 20 and below FPS. When originally with a lesser system, and the same GPU I was running Overwatch at 60 FPS on all maxed settings.
Sounds like it may be using the iGPU instead of the discrete GPU, check the BIOS to see which is set there, also check for BIOS update for mobo... and if that is already set there, maybe try a different driver version for the GPU.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
What driver version were you using before and what one are you using now?
Other systems I've built:
That's actually a really good shout. I'll check.
Thanks.
In power management did you set the performance to high performance?
maybe windows messed up? did you reinstall the os?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
I was using 365.19 which carrid over to the new install and was still creating the lag.
I then updated to 368.22, still persisted.
1 minute ago, Podgy said:
I've activated that, no difference.
How did the suggestion by paddy go? Did you check the bios?
My RIG:
CPU: Intel core i7 4790k     Motherboard: Msi krait edition z97      RAM: Crucial Ballistix Sport 16GB      GPU: EVGA GTX 1070 8GB Gaming Black Edition     Case: Thermaltake core v71   Storage: Samsung 850 pro 256gb OS, WD green 2Tb, WD blue 500GB, WD blue 350gb, Segate barracuda 250gb      PSU: NZXT hale82 v2 700w     Cooling: Noctua nh-d15   Operating System: Windows 10 Pro
Hmm, check task manager and make sure that your CPU is running normally, and then check MSI Afterburner or EVGA PrecisionX and make sure your GPU is running at its full potential, also make sure your GPU doesn't have any dust or dirt in it since it is quite old
1 hour ago, Podgy said:
Same OS, just relocated the SSD to my new build.
Actually I thinm you may have to do a "refresh" of windows... relocating your drive from your old system may have caused problems as your old system had it's own chipset drivers etc and the new system needs the correct ones. I'd try refreshing windows so that it takes everything off except windows itself, then install drivers etc it needs.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Just checked the BIOS, I'm definitely using my 670.
And that actually doesn't surprise me too much. In terms of doing that on Win10, is there an easy way? Or do I have to create a bootable USB like the old days?
This is after 5 minutes of enduring 5FPS in Overwatch.. Haha:
https://gyazo.com/1ed1434aaad61aa74da633efaafa9c25
I cleaned the GPU before installation into the new system.
And that actually doesn't surprise me too much. I terms of doing that on Win10, is there an easy way? Or do I have to create a bootable USB like the old days?
I believe there should be an option within windows for refreshing it, keeps files and stuff but resets drivers and things. Try that.
If that fails, try a full reinstall from a bootable USB.
Just go into System>update and security>recovery and go to [reset this PC]
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
It looks like the problem is resulting in your CPU, I'm sure you can see its only using aboutt 8% CPU usage where your GPU is maxed out. Just make sure this is enabled.
Back,
I performed a reset, reinstalled chipset drivers from:
https://www.msi.com/Motherboard/support/Z170A-GAMING-M5.html#down-driver&Win1064
Installed Nvidia GeForce Experience and updated the driver to:  368.22
Ensured performance was set to 'High Performance'.
Still the same crazy lag. Interesting.
I did notice that, however the overall usage is 33%. And there wasn't all that much going on in the game.
