Hey all, new around these forums. I have a gaming-related issue that I could use some help with.
So here's my problem: I'm moving to a new appartment soon, and I want to find a way to permanently connect my pc to my tv, in order to easily game, watch movies, or surf the web, as if I were working off my monitor. The pc and the tv will only be about 5 metres away, but having a wire going from one to the other would be very inconvenient. Pathing the wire inside the wall or under the floor is not an option unfortunately. Even if I try to hug a wall with a wire, I'd have to go past a door, which is very inconvenient.
Therefore, I've been looking at possible solutions. The first one that came to mind was using a wireless HDMI connection. However, I've never tried these. I live in Argentina, and have family travelling to the US soon, so I can have them get it for me there. Unfortunately, once it's purchased, there's no going back, so I want to make sure it fits my needs. So, has anyone tried wireless HDMI for gaming? How bad is the lag over short distances like mine (no walls in between btw)?
Also, any other suggestions you guys might have? I've been told about the Steam Link, but how does that work with non-steam games? Or what if I want to watch a movie I have downloaded on my pc, or browse the internet with a mouse and keyboard, like I would be able to do with an HDMI connection?
Anyway, all ideas are welcome.
https://linustechtips.com/topic/602073-recommend-a-solution-for-my-gaming-setup/
I was going to suggest wireless HDMI or bluetooth.
I've used neither but I assume there will be some nice lag there.
Why not just rearrange the furniture?
There is also HDMI over Ethernet.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
Ok, I drew a little sketch so I can more easily explain this. The appartment isn't very large, and this is the main room (place for the tv, pc, probably a table and some chairs somewhere in between). As you can see, any wire going form the pc to the tv has to pretty much go right though everything.
I would use a usb extension and run it under the ceiling. It is basically what I have done with my setup.
Ya, that would be a pretty long cord and would look rather ugly. Not enough room south of the PC?
Wireless HDMI, Bluetooth, and HDMI via Ethernet are really your best bet.
I'll just guess at you experiencing some sort of lag as is usually traditional with wireless connected devices.
But it's never bad enough to take away from gameplay in most situations.
If it was, it probably wouldnt be a thing.
Run it in/along the ceiling lol, no one ever looks up there right?
Use the following spec style and help us spread the revolution to the rest of LTT!
"Rylo Ken"
Screenaninator: Asus Strix GTX 970
Procrastinator:Intel I7 4790K @4.0GHZ
Stickaminator: Kingston HyperX Fury (2x8)
Powermathingy: EVGA 650 GS Fully Modular
attachamajiggy: MSI Z97S SLI Krait Edition
Remembrerthing: Samsung 850 EVO 250 GB
Buttonboard: Corsair K70 RGB (browns)
Hearamagargle+talkamagargle: Logitech G35
See-A-Move-O: Logitech G502
5 hours ago, BudderedPopcorn said:
Linus just the other day put out a video that used wireless HDMI. I remember them saying that there was little to no lag, but small spikes at times.
Can you link that? I've been able to find it. In fact, I haven't found too many video reviews of wireless HDMI that are less than 2 years old...
Well, thanks for all the replies! I think I can gather that most of you would recommend trying to make the wire work, rather than getting a wireless HDMI. It's a pitty that there isn't much info out there about how viable these are for gaming...
Anyway, guess I'll go back and get some measurements to see if I can make the wire path in an unobstrusive way. If not, I'll be posting on how well the wireless HDMI works hehe. Thanks again!
