Hi,
I'm trying to build my first ever PC. These are parts that I have chosen so far. Need every opinion I can get.
1. Budget & Location: 600 eur. Lithuania
2. Aim: Gaming (Diablo 3, Witcher 3 ), sometimes autocad (2d)
3. Monitors: 1 for now
CPU:
AMD FX-6300 3.5GHz 6-Core Processor
Motherboard:
Gigabyte GA-970A-UD3P ATX AM3+  or  MSI 970 GAMING ATX AM3+
GPU:
Sapphire AMD/ATI Radeon R9 380 4GB
Memory:
Crucial Ballistix 8GB (2 x 4GB) DDR3-1600 Memory
Storage:
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Case:
Aerocool Aero-500 ATX Mid Tower Case
Power supply:
PSU Seasonic S12II-520 520W 80 Plus Bronze retail
Thanks and sorry for bad English.
Updated.
https://linustechtips.com/topic/601466-first-budget-build-need-tips/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  (€181.08 @ Mindfactory)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard  (€77.88 @ Amazon Deutschland)
Memory: Crucial 8GB (2 x 4GB) DDR4-2133 Memory  (€28.96 @ Amazon Deutschland)
Storage: OCZ Trion 100 120GB 2.5" Solid State Drive  (€49.99 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€48.95 @ Amazon Deutschland)
Video Card: Asus GeForce GTX 950 2GB Video Card  (€158.89 @ Amazon Deutschland)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case  (€47.89 @ Amazon Deutschland)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply
Total: €593.64
Generated by PCPartPicker 2016-05-26 11:32 CEST+0200
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
10 minutes ago, ModestasHydro said:
Hi,
i'm trying to build my first ever PC. These are parts that i have chosen so far. Need every opinion i can get.
CPU:
Motherboard:
GPU:
Gigabyte Radeon R9 380 4GB SOC Video Card
Memory:
Storage:
Case:
Power supply:
Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply
If you can get an i3 + board for less money then do that. Basically the FX 6300 and i3 4170 perform the same - get the cheaper one. GPU is fine but avoid Gigabyte and Asus - get a 380 from XFX/PowerColor/Sapphire/MSI
The memory is fine
Storage is fine
Case doesn't matter
The PSU is rubbish - get a SeaSonic S12II 520W - the CX and VS from Corsair are terrible quality
Total: €593.64
No sense in going for i5 + 950 on a budget build - i3 + 380 would deliver 40% better performance.
12 minutes ago, ModestasHydro said:
Hi,
CPU:
Motherboard:
GPU:
Memory:
Storage:
Case:
Power supply:
Are you planning to aim for any upgrading or future proofing?
It might be worth thinking about the workload you will be performing with CAD as sometimes it may slow down with 8GB RAM.  Just a thought as RAM is not the most expensive part of a build to pick up 2 x 8GB sticks or 1 x 8GB with the option to upgrade if it is not enough?  Worth thinking about leaving upgrade-ability as easy as possible.
As long as it's dual-channel (2sticks) it will be fine - 16GB is not needed
The memory is fine
Storage is fine
Case doesn't matter
1
FX 6300 is cheaper.
Not planning major upgrade   in near future only SSD.
1 minute ago, ModestasHydro said:
FX 6300 is cheaper.
Then get the FX 6300 - change the GPU OEM and a get a better PSU
21 minutes ago, ModestasHydro said:
FX 6300 is cheaper.
But how much cheaper? if it's less than 3/4 of the price of the i3 then go for the 6300 else i3 :)
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
FX 6300 is 104 eur  I3 is 118 eur.
But why I should go for I3 ? if 6300 and I3 perform same. Any other advantages ?
'preforms the same', that really does depends on the games as the 6300 will preform better in games that utilizes all cores or has the 4 core min requirement (as the i3 isn't a true 4 core, it's a dual core with 4 threads) but the IPC on the i3 is so much better than in 1-2 core situation (and games), it will preform a lot better :P
I guess go with the 6300 as it is cheaper :P which means better PSU (although a xfx ts/seasonic PSU are cheaper than the cx here while they are much better in quality :D)
You can find some really cheap 6300's on the used market. Got one with a good after market cooler for 75usd total. At that budget used is king.
