Graphics for my system
Go to solution Solved by Drown,
What about the new volcanic island series like the R9-280x? or R9-290x, but you should wait to see.
He said that he don't want to wait for the 9000 serie because he can get a cheaper 7000 serie card. Also, he's talking about 7770 and 7850, definitely not the same price range as a R9-290x .. =P
To the OP, go for the 7850, if these are your only two options/choices. ;)
So, need a bit of advice I have a AMD A6 5400K oc to 4.2 stable, (i know not the best but i didn't want to wait) and i will be getting a AMD Graphics card but cannot decide which one, i will not get a 9000 series cause i can get a 7000 card on the cheap and cannot wait to get my gamer head on #PCGamer (haha) anyway deciding between 7770 XFX DD 1GB or Asus DC2 7850 2GB. I will runnning 2 monitors but only one for gaming so any recommenced i would be grateful, and to what extend would my cpu bottleneck these video cards.
Thank you
Jack
Main: AMD Athlon X4 750K| Coolermaster Hyper TX3 EVO | Gigabyte GA-F2A75M-HD2 | 8GB Kingston 1333mhz | WD Caviar Green 1tb | Coolermaster N200 | OCZ coreXstream 500w | Sapphire Radeon HD 7850 2GB | |Kingston 3k ssd 128gb |
https://linustechtips.com/topic/60139-graphics-for-my-system/
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/60139-graphics-for-my-system/#findComment-816785
https://linustechtips.com/topic/60139-graphics-for-my-system/#findComment-816796
Well I did say Volcanic Island GPU in general, well if he can't wait I guess best bet is 7000 series
https://linustechtips.com/topic/60139-graphics-for-my-system/#findComment-816802
