It's a new rig
MB: Asus z170m plus
CPU Intel i5
ram kingston hyper x 8gig single channel
Psu evga 500w non modular
Gpu evga 960
so it it powers up but does not output a display
have tried removing Gpu ram as well as any other things
only thing on mb is CPU
reset cmos
https://linustechtips.com/topic/600918-power-on-no-display/
I would try swapping the ends of the cable around. As in, the end of the cable that is in the GPU, you should try swapping to the port on your monitor and vice versa. It may sound simple, but it can actually work sometimes. And if that method doesn't work, then I would try using a different connection.
"How can someone win if winning means that someone loses?" -John Paul Larkin
https://linustechtips.com/topic/600918-power-on-no-display/#findComment-7800069
Are you 100% sure that he monitor and the GPU both work it. It would be pretty unlikely if they are new and don't work, but hey, I don't know your scenario. But if you are unsure if they work or not then put them into another system and see if they work or not.
https://linustechtips.com/topic/600918-power-on-no-display/#findComment-7802686
