Really High CPU Temps?
Solved by aisle9,
46 minutes ago, SAT01 said:I ran the Intel XTU CPU Stress Test and the highest CPU Temp I got was 70C, I didnt change any of the settings besides setting my voltage to Manual instead of Adaptive(Same voltage though) I dont know whether this is just a wimpy stress test but my Usage hovered around 100% the entire time.
I used MSI Afterburner to record the temps(I ran it in the background whilie I ran the Stress Test)
I'm having a hard time finding something to worry about here. I'd just keep an eye on it. If the temps climb any or you really just feel like something's wrong, you can always play with your fan curves or re-seat the cooler.
