Hey guys I'm working on functions to go through my binary search tree recursively.
However, I cannot seem to correctly call my recursive functions while also moving to the
left or right child respectively.  Any help is appreciated.
The functions are:
int tree::insert(const tree & toAdd)//Insert a new node into the tree
    node * temp= new node;
    temp -> entry= toAdd;
    if(!temp)
        delete temp;
        return 0;
    if(!root)
        node * root = new node;
        root -> entry = toAdd;
        return 0; //Return it was inserted
    if(root -> entry.chapter > toAdd.chapter)
        insert(root -> left, toAdd);
    else if(root -> entry.chapter < toAdd.chapter)
        insert(root -> right, toAdd);
int tree::edit(char * keySearch, char * noteEdit, tree & found)
    //Edits the description of the note if it is found
    if(!root)
        return 0;
    //If keyword matches key search
    if(root -> entry.keyword == keySearch)
        // return the FOUND node back to main
        // Set roots description to noteEdit
        root -> entry.notes = noteEdit;
    //If keyword is larger than search keyword
    if(root -> entry.keyword > keySearch)
        root = root -> right;
        edit(keySearch, &noteEdit, &found);
    //If keyword is smaller than search keyword
    else if(root -> entry.keyword < keySearch)
        root = root -> left;
        edit(keySearch, &noteEdit,&found);
I am also not sure if my retrieve function works and if it would actually return the found match
back to main.
int retrieve(char * keySeach, tree & found) const;
int tree::retrieve(char * keySearch, tree & found)const//Search for the tree that matches
    if(!root)
        return 1;//That it was not found because empty.
        retrieve(keySearch, found);
        return found;
    else
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/600787-recursive-function-call-help/
