What's the rest of your system specs?
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
And I have a 660 right now but want to upgrade for battlefield 4, mostly just need more VRAM
760 has the same amount of vram adding a additional card wont increase the vram
Specs cpu:  i7 4770k  mobo: z87-pro RAM: Corsair vengeance 8GB GPU: EVGA GTX 770 HDD: WD blue 1TB psu: TX750M case: 550D cooling: H100i monitor: Dell U2410/Samsung sa350
I <3 senheiser, ASUS, Corsair, Intel
I have a seasonic 650 watt 80 plus bronze power supply, and I was wondering if I could sli two msi 760s with this PSU, thanks!
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151106
You should be fine...........But, if you have the means, it may not hurt to invest in
an upgraded PSU. Not sure how necessary that would be, other than peace of
mind. :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151107
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151108
If you going for a BF4 upgrade, I would go AMD right now. A lot of good things promised now with Mantle..... You can pick up a 7950 for $200.
5820K - ASUS X99-A - 16GB Corsair LPX - HD 7970 GHz - Qnix 1440p @ 96Hz - Waiting for Polaris/Pascal
Yeah I'm definitely gonna have to think about whether or not to get AMD, but I don't know I just personally prefer nvidia.
760 has the same amount of vram adding a additional card wont increase the vram[/quote
I would get the msi twin frosr 4gb one
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127748
apparently the 760 has to low of a memory bandwidth to use the whole 4gb, 7950 comes with free games and costs less if you haven't already bought a 760.
760's are very efficient and Seasonic makes excellent PSU's.  You'll be fine...
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
