My Instructor said that we need to create an OOP system we will choose one between Java and PHP only. Any idea what kind of system should I create? And he said that we can't use the Netbeans IDE kinda confuse coz all the time in our University we always use Netbeans as an IDE for Java now we can't? Do you know exactly what he meant by that? I want a system that is quite easy to code, and give me some special features on my system. Thank you.
https://linustechtips.com/topic/600114-need-help-on-my-thesis/
basic micro blog site, basically just a news feed of what everyone posts which a like/dislike system. Simple and will make full use of PHP, MySql.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/600114-need-help-on-my-thesis/#findComment-7787601
I don't know why you are using that garbage anyway, IntelliJ is far superior.
The single biggest problem in communication is the illusion that it has taken place.
https://linustechtips.com/topic/600114-need-help-on-my-thesis/#findComment-7787640
You'd be surprised. During my degree I just finished and they were teaching us web services using vb6. Admittedly for the course work you could use any language but still.
https://linustechtips.com/topic/600114-need-help-on-my-thesis/#findComment-7787668
That's the only one IDE for Java in our University, Eclipse is my previous IDE since I had a Java subject and we are using Netbeans I transfer to Netbeans coz the hotkey shortcuts in Eclipse is different to Netbeans..
https://linustechtips.com/topic/600114-need-help-on-my-thesis/#findComment-7787695
Honestly from the volume of academic related posts that I've seen on here it really doesn't surprise me. I've even ranted about it before. It's a terrible way to set people up for going into the industry... Essentially preparing them with out of date technology, principles and practices after they have handed over the £££££... do not get me started.
So? Use a different one! Is there a regulation that states "you must use Netbeans or you will fail"?
What...?
https://linustechtips.com/topic/600114-need-help-on-my-thesis/#findComment-7787709
Honestly from the volume of academic related posts that I've seen on here it really doesn't surprise me. I've even ranted about it before. It's a terrible way to set people up for going into the industry... Essentially preparing them with out of date technology, principles and practices.... do not get me started.
What...?
You don't know hotkey shortcuts for the codes? So if I'm using Eclipse in home the shortcut keys is different in School, coz in our school they use Netbeans. In our block when we have a machine problem the fastest one finished the problem got a bonus score. so thinking a way to solve a problem will take a lot of time for others plus the typing, thats where the shortcuts help instead pressing 10 buttons on your keyboard you will only need to press 3.
https://linustechtips.com/topic/600114-need-help-on-my-thesis/#findComment-7787744
I'd totally suggest C++ if you had the choice. Are those two languages given because he doesn't know other languages? (I remember such from my studies...)
Write in C.
https://linustechtips.com/topic/600114-need-help-on-my-thesis/#findComment-7788011
I don't even understand what you are trying to say or ask, your points are convoluted, make very little sense and keep jumping all over the place.
https://linustechtips.com/topic/600114-need-help-on-my-thesis/#findComment-7788735
Some ideas
  • Blog
  • Forum
  • Online store
  • Online bank
Make sure whatever you choose can meet all the project requirements.
If he says you can't use Netbeans, then he means you can't use Netbeans. We can't know why he decided on this rule. I would assume this also means he doesn't want you using any IDE at all (ie: Eclipse, IntelliJ, etc) but again, we can't know what he's thinking or what he said. If you need clarification, go ask him about it.
If IDE's are out for some reason, then there are plenty of text editors you can use. Sublime Text, Atom, Notepad++ (if using windows), Vim, Emacs, etc. Hopefully you know how to run/debug your code without an IDE.
https://linustechtips.com/topic/600114-need-help-on-my-thesis/#findComment-7788856
Do you really need to create "a system" or just a script/program?
I've personally enjoyed image processing courses the most.
For example, I've made a program that removes fences from zoo photo's.
Or a program that stitches images together (cut one picture in half, dont try to stitch two seperate pictures or you'll have to work around radial distortion and fix the colors).
Maybe AI is more your thing, then I would suggest looking into Neural Networks. They're actually pretty easy to understand.
All the previously mentioned subjects could be done in many languages, although Python is probably the easiest (using numpy/scipy/opencv/tensorflow for performance).
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
https://linustechtips.com/topic/600114-need-help-on-my-thesis/#findComment-7791626
