I have a TP link ,obviously a wired connection is faster than a wireless connection, but compared to my phone i dont get as fast a speed as i do on my phone. The TP link (socket wired internet thing) seems to be slower than the wireless connection.
does anyone know how i speed up the wired connection?
https://linustechtips.com/topic/600107-internet-speed/
Check for kinks in the ethernet cable.
"You don't need headphones, all you need is willpower!" ~MicroCenter employee
How to use a WiiMote and Nunchuck as your mouse!
Specs:
Graphics Card: EVGA 750 Ti SC
PSU: Corsair CS450M
RAM: A-Data XPG V1.0 (1x8GB) (Red)
Procrastinator: Intel i5 4690k @ 4.4GHz 1.3V
Case: NZXT Source 210 Elite (Black)
Speakers and Headphones: Monitor Speakers and Phlips SHP9500s
MoBo: MSI Z97 PC MATE
SSD: SanDisk Ultra II (240GB)
Monitor: LG 29UM68-P
Mouse: Mionix Naos 7000
Keyboard: Corsair K70 RGB (2016) (Browns)
Webcam/mic: Logitech C270
https://linustechtips.com/topic/600107-internet-speed/#findComment-7787207
What is your internet speed? If your internet speeds are higher than 100mbps then unless your router/switch has gigabit ports with you also having cat 5e (and better cables) and a gigabit NIC on your PC then that could be the reason for slower internet speeds :P as AC can handle upto "1.6gbps" of data...(which in real world terms, it can't but still more than 100mbps so...yeah)
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/600107-internet-speed/#findComment-7787227
