Hi
I am building a gaming pc. Before i did not care about the case as long as it worked,
but now i realize i need a case that's easy to work with. I am on a $1500 budget so it has to be
 under 100$ because its my first time i'm looking for something simple so it will be easy to build,
but still maintain a cool clean look. I have looked up some cases but still cant find any that i would like.
So basicly i need help looking for a case i would appreciate your help.
FredPC
https://linustechtips.com/topic/599873-first-build-case/
Do you have any more restrictions/ requirements/plans for the future that limit your needs? Only a price point is really vague but I will go ahead and suggest the Define R5 or Define S depending on your local prices get the R5 if you can but the Define S is a pretty good bags for the buck. Hardware canucks recently featured the Zalman Z9 Neo (or something) and it also looked pretty slick while being a solid case for a fair price. Other standart recommendations would be the H440 or H340... Go very us something like a colour, please. Do you need a window/want?
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/599873-first-build-case/#findComment-7785011
Well i probably add more ssds and hdd in the future  and i would like i window but i don't really need it
https://linustechtips.com/topic/599873-first-build-case/#findComment-7785023
