Help please! Weird sh*t happening!
I am noticing artifacts in unigine valley. I have a list of possible problems, need help please! Thanks!
So here are the basic specs of my PC:
fx-8320
2*4gb hyperxfury red ddr3-1866 cl9
msi twin frozr v gtx 970
cx500m
cougar mx300 with inc. fan moved to bottom of front panel, top-back replaced with arctic f12 pro.
Here are the 5 main variables I figured it may be:
I recognise my case is cheap, could it be thermal throttling?
Is it a cpu bottleneck? (bought an aftermarket cooler, can't use yet still waiting for thermal paste)
Is it my OC? using msi afterbburner + msi extended bios. Running at 1.187v, +175 core, +425 mem.
Is it my monitor? It is below both the resolution and refresh rate I am running valley at. It is only a placeholder, upgrading soon ;)
Thanks so much again for helping!
its your overclock. turn it down and it will be fine
Builds:
Probably your graphics card oc. If you don't give it enough voltage it will have artifacting. But don't givr it too much voltage. If you have a bad chip it might not oc that well and you will need to lower the clock speed
CPU: Intel Core i7-6700k | Motherboard: AsRock Fatality Z170 Gaming K6 | RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4 2666MHz Red
GPU: EVGA GeForce GTX 1080 FTW GAMING ACX 3.0 | Case: Corsair Carbide Clear 400C | Storage: PNY CS1311 480GB | PSU: Corsair RM750x
Display(s): Samsung S24D390HL 23,6"(looking to upgrade) | Cooling: Corsair H110i GT | Keyboard: Logitech G710+ Gaming Keyboard Cherry MX Brown switches
Mouse: Corsair Sabre optical | Sound: AKG K273 and Blue Yeti microphone | Operating System: Windows 10
Thanks for such instant responses! I see linus's fans wanna go FAAAAAST! HAHA-HAHA-HAHA!!!!!!!!
6 minutes ago, G4merG3ddon_Dafs said:
Thanks for such instant responses! I see Linus's fans wanna go FAAAAAST! HAHA-HAHA-HAHA!!!!!!!!
Couple things that I've noticed.
Your CPU is old. Like old. You've got it overclocked I assume? Plus the CPU cooler isn't the greatest to cool your CPU. I would change that
You've got a CX500 PSU, which is not the best PSU's out there.
Your GPU could be under performing, due to your CPU.
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 | GPU: Nvidia GTX 1060 6GB Zotac Mini | Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB  | HDDs: 1x 250GB & 1x 1TB WD Blue | Monitors: 24" Acer S240HLBID + 24" Samsung  | OS: Win 10 Pro
Audio: Behringer Q802USB Xenyx 8 Input Mixer |  U-PHORIA UMC204HD | Behringer XM8500 Dynamic Cardioid Vocal Microphone | Sound Blaster Audigy Fx PCI-E card.
Home Lab:  Lenovo ThinkCenter M82 ESXi 6.7 | Lenovo M93 Tiny Exchange 2019 | TP-LINK TL-SG1024D 24-Port Gigabit | Cisco ASA 5506 firewall  | Cisco Catalyst 3750 Gigabit Switch | Cisco 2960C-LL | HP MicroServer G8 NAS | Custom built SCCM Server.
