I recently built a new PC, but i am stuck without a graphics card until the 1080 releases. Anyways my monitor keeps flickering off and on, but i don't see why that's happening since the 6700k has integrated graphics, anybody know what's happening?
PCPartPicker part list: http://pcpartpicker.com/p/fnb9jX
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($339.99 @ B&H)
CPU Cooler: Corsair H110 94.0 CFM Liquid CPU Cooler  ($111.99 @ Newegg)
Motherboard: Asus MAXIMUS VIII FORMULA ATX LGA1151 Motherboard  ($348.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($74.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($85.79 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Case: NZXT H440 (Matte Black) ATX Mid Tower Case  ($99.99 @ Directron)
Operating System: Microsoft Windows 10 Pro OEM (64-bit)  ($138.89 @ OutletPC)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard  ($169.99 @ B&H)
Mouse: Razer Mamba Wireless Laser Mouse  ($129.99 @ NCIX US)
Other: BenQ EW2750ZL 27" ($199.00)
Other: Photive BTH3 Wireless ($39.95)
Other: GTX 1080 ($699.99)
Other: EVGA SuperNOVA 750w G2 80+ Gold (Fully Modular) ($109.99)
Total: $2596.93
https://linustechtips.com/topic/599776-graphic-problems/
Are you able to try out another monitor? E.g. a TV?
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7783959
26 minutes ago, DatDrunkenPanda said:
try another cable just in case it's that
It's not the cable and it's not the outlet, because i unplugged everything except for the monitor and pc! It's becoming difficult to even use my pc, because the flickering is almost non-stop.
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7784091
if it's flickering without anything plugged in then it could be a fault with the monitor
can you try plugging another device into the monitor to be sure?
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7784125
4 minutes ago, Crunken said:
Try another monitor or another cable, also try another output from the motherboard to see if it's the port your using
As i said i don't have another monitor and i already tried using another cable. Also the monitor seems to only have one hdmi port.
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7784202
Cable or defective monitor for what i'm seeing.
Do you have a case beeper in hand? You could wire it up to your mobo to see if there's anything wrong.
I had a similar problem in my setup when i built it and it turned out it was bad ram...
Project Diesel 5.0: Motherboard: ASRock Fatal1ty X370 Professional Gaming /// CPU: Ryzen 5 3600X  /// CPU Cooler: Scythe Ninja 5 /// GPU: Zotac AMP Extreme RTX 2070 /// RAM: 2x 16gb G.Skill Ripjaws V @3200mhz /// Chassis: Lian Li Lancool One Digital (black) /// PSU: Super Flower Leadex III 750w /// Storage: Inland Premium 1TB NVME + Toshiba X300 4TB
Peripherals: Mice: Cooler Master MM720 /// Keyboard: Corsair K70 MK2 SE (Cherry Silver), Blitzwolf BW-KB1 (Gateron Reds) /// Monitor: Acer XZ320Q 32' (VA, 1080p @240hz) /// AMP: Topping PA3 (Onkyo Integra A-817XD undergoing restoration) /// DAC: Weiliang SU5 /// Speakers: AAT BSF-100 /// Mike: Alctron CS35U /// Headphones: Blon B8, ISK MDH-9000
Living room: TV: Samsung QLED Q7FN 55' 4k /// Amplifier: Denon AVR-X2400H /// Speakers: DALI Zensor 7 /// Consoles: Sony PS4 Pro 1TB, Sony PS3 500gb /// LD/CD/DVD: Pioneer DVL-909 /// Power Supplies: Upsai ACF-2100T + GR Savage CDR2200EX
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7784221
Let me ask, do you a LCD or Plasma or LED TV?
I'm using my PC in a LCD TV via graphics card HDMI, you could at least test if it's monitor issues or not
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7784229
We can rule out the problem being with the cable, since i've tried 3 different cables! I don't even know what a case beeper is, but i know my ram is good and i feel the monitor is fine as well since it was working when i had the graphics card in my system!
As linked in the original post i use the BenQ EW2750ZL 27" Monitor, http://www.amazon.com/BenQ-EW2750ZL-Revolution-Enjoyment-Monitor/dp/B013FDIUFA
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7784264
As linked in the original post is use the BenQ EW2750ZL 27" Monitor, http://www.amazon.com/BenQ-EW2750ZL-Revolution-Enjoyment-Monitor/dp/B013FDIUFA?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s01
This is a beeper or PC speaker if you will, great for diagnostics.
Could it be your mobo, maybe? If you could only like test it on a TV or something to make sure...
F04794-30pcs-Desktop-font-b-Pc-b-font-Computer-Mainboard-Motherboard-Case-font-b-Internal-b.jpg
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7784277
I'll see if i can use my friends tv and pc speaker makes more sense now, i had one of those with my previous motherboard, but i guess they didn't include one with my current motherboard.
Normally those come with the cases themselves, mine has a giant 8Ω one screwed to the front of the chassis
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7784311
7 minutes ago, Cottontails said:
So i've been using an hdtv for a little while now and no issues, i guess it was the monitor, but i don't understand it, because it was working fine before i removed the graphics card?
What should i do, do you think i should return the monitor?
I believe you should try to return the product if it's defective, try to test with another pc or laptop just to make sure.
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7784386
So the monitor works with the laptop and worked with the PC when it had a graphics card, the only time it turns off and on is without the graphics card in my PC. Also the hdtv works perfectly with my PC so it's not the motherboard either.
So what is the issue, i'm clueless?
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7784577
You could try and contact benq customer support can be a pain in the ass but they may know something about the problem
CPU: Intel Core i7-6700k | Motherboard: AsRock Fatality Z170 Gaming K6 | RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4 2666MHz Red
GPU: EVGA GeForce GTX 1080 FTW GAMING ACX 3.0 | Case: Corsair Carbide Clear 400C | Storage: PNY CS1311 480GB | PSU: Corsair RM750x
Display(s): Samsung S24D390HL 23,6"(looking to upgrade) | Cooling: Corsair H110i GT | Keyboard: Logitech G710+ Gaming Keyboard Cherry MX Brown switches
Mouse: Corsair Sabre optical | Sound: AKG K273 and Blue Yeti microphone | Operating System: Windows 10
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7784593
now that is a very weird situation you are encountering
https://downloadcenter.intel.com/download/25948/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88195
try updating the Intel Graphics Driver to the latest version
In the Intel Display settings, make sure your monitor refresh rate is set to 60Hz
Also in the BIOS, if you have not try this
Set the Integrated to be the primary display and allocate 64MB for video memory if you set video RAM too high.
Last but not least
also try running in Safe Mode and see if the flickering still persist with the basic display driver
Just to rule out drivers issues
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/599776-graphic-problems/#findComment-7787320
