With your requirements even a 980Ti at ~$570 still puts you over budget by about $100. I'm sure some of the forum builder wizards will manage to tweak it a bit to come in at or under budget:
http://pcpartpicker.com/p/CssbsY
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/599730-1300-budget-need-help/#findComment-7783492
9 minutes ago, fred32xp said:
can someone make me a good parts list for my new pc with a gtx 980/980ti 1080 and an i7 6700k
1300 budget
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($339.99 @ B&H)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.49 @ Amazon)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($79.99 @ Amazon)
Memory: G.Skill NT Series 16GB (2 x 8GB) DDR4-2400 Memory  ($53.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($85.79 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($44.99 @ SuperBiiz)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case  ($44.99 @ SuperBiiz)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($74.99 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($28.99 @ SuperBiiz)
Other: GTX 1080 ($599.00)
Total: $1382.21
Generated by PCPartPicker 2016-05-22 12:28 EDT-0400
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/599730-1300-budget-need-help/#findComment-7783495
PCPartPicker part list: http://pcpartpicker.com/p/tvvwt6
Price breakdown by merchant: http://pcpartpicker.com/p/tvvwt6/by_merchant/
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler  ($33.74 @ Amazon)
Motherboard: Gigabyte GA-Z170X-Gaming 5 ATX LGA1151 Motherboard  ($139.99 @ Micro Center)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($49.99 @ Newegg)
Case: Corsair Carbide Series 300R Windowed ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($64.99 @ Newegg)
Total: $1363.48
Generated by PCPartPicker 2016-05-22 12:33 EDT-0400
This should be good. It has a windowed case to show your colour scheme and all the expected specs at this price point. The CPU cooler is personal preference and I think this looks better than the 212 evo but your choice, and you could add a HDD later on for more storage.
https://linustechtips.com/topic/599730-1300-budget-need-help/#findComment-7783540
1 hour ago, fred32xp said:
can someone make me a good parts list for my new pc with a gtx 980/980ti and an i7 6700k
PCPartPicker part list: http://pcpartpicker.com/p/cKQCpg
Price breakdown by merchant: http://pcpartpicker.com/p/cKQCpg/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($297.30 @ Amazon)
Motherboard: ASRock B150 Gaming K4 ATX LGA1151 Motherboard  ($94.99 @ Amazon)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($57.10 @ NCIX US)
Case: Fractal Design Core 2500 ATX Mid Tower Case  ($55.99 @ Directron)
Power Supply: Antec Green 550W 80+ Bronze Certified ATX Power Supply  ($61.99 @ SuperBiiz)
Other: gtx 1080 ($599.00)
Total: $1290.84
Generated by PCPartPicker 2016-05-22 13:35 EDT-0400
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/599730-1300-budget-need-help/#findComment-7783779
1 hour ago, Matias_Chambers said:
You don't do video editing or anything like that do you?
Good question cos if you are only using it for gaming, an i5 would be more than sufficient. Also, do you plan on overclocking cos if so, you could do with a better CPU cooler and if not, you could save a bit going for a non-k CPU and a H170 board instead.
https://linustechtips.com/topic/599730-1300-budget-need-help/#findComment-7784199
