Help- Deciding between Two Computer.
Solved by HPWebcamAble,
If you HAVE to chose one, get the one with the GTX 970 and 6700.
But just keep in mind that they charge for their custom case and putting it all together, you could build the same computer for $100-200 less
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
