Posted May 21, 2016 (edited) Note: this is software terms not physical, oh well this might not work if the usb itself has gone bad. So here is how we do it. Download a simple program called "Bootice" here Plug yo drive in - Then Win10/8: RClick Start - Disk Management Win Vista/7 : Start - Rclick Computer - manage - Disk Management. you should see this now scroll till you see that flash drive You see the problem, half of its allocated. The reason this happens (I theorize) is that you pull you usb without ejecting it, the primary partiton(data gets stored) gets formatted then replaced with 200 MB EFI Partition.(which is required with fat32) To fix it open Bootice Destination is your flash drive then press Parts manage. press re partitioning. do as the picture says it wil tell you prompt you if you are an idiot, but since youre not press yes anyway. then you are done! look it works What this is useful for 1) see if ebay drives are actuall size 2) fix your mums flash drive that she needs. 3)??? 4) profit. disadvantage 1)lose original data. 2) idk. Edited May 21, 2016 by josephaltareb deleted unnesisary photo Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 daayum that's useful, don't need it atm but still, adding this one to useful bookmarks If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3 Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 Just now, samcool55 said: daayum that's useful, don't need it atm but still, adding this one to useful bookmarks in fact i fixed 3 junk usb's which people threw at me. Free usb's! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 Alternatively use the HP USB Tool that does this in a few clicks without doing anything yourself. My current build - Ever Changing. Number 1 On LTT LGA 1150 CPU Cinebench R15 http://hwbot.org/users/TheGamingBarrel Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 Just now, TheGamingBarrel said: Alternatively use the HP USB Tool that does this in a few clicks without doing anything yourself. i did not know about that but thanks this just takes 30 seconds of yo time. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 Just now, josephaltareb said: i did not know about that but thanks this just takes 30 seconds of yo time. This software is even less, just select drive and go. My current build - Ever Changing. Number 1 On LTT LGA 1150 CPU Cinebench R15 http://hwbot.org/users/TheGamingBarrel Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 1 minute ago, TheGamingBarrel said: This software is even less, just select drive and go. i tried those types of software before, but it didnt work well. I always do this method. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 1 minute ago, josephaltareb said: i tried those types of software before, but it didnt work well. I always do this method. Did you know that command prompt is also capable of the same??? You just have to type about 5 command lines and BOOM! It's done! Indus Monk = Indian+ Buddhist Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 2 minutes ago, AmbarChakrabarti said: Did you know that command prompt is also capable of the same??? You just have to type about 5 command lines and BOOM! It's done! show me, again this is my method and it takes me a minute, nothings gonna change my mind. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 2 minutes ago, josephaltareb said: show me, again this is my method and it takes me a minute, nothings gonna change my mind. https://tails.boum.org/doc/first_steps/reset/windows/index.en.html Indus Monk = Indian+ Buddhist Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 1 minute ago, AmbarChakrabarti said: https://tails.boum.org/doc/first_steps/reset/windows/index.en.html eh, too much commands for me to remember, i work in a shop where i have to remember a lot of things you know. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 1 minute ago, josephaltareb said: eh, too much commands for me to remember, i work in a shop where i have to remember a lot of things you know. You can always make a batch file for that... But if you can't, then oh well, I was just giving you some info Indus Monk = Indian+ Buddhist Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 21, 2016 1 minute ago, AmbarChakrabarti said: But if you can't, then oh well, I was just giving you some info that is useful too! just not for me. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
