Hello guys,
just today I got my Modmic 4.0. On my Alienware 15 Notebook it works fine, but on my Tower PC I do not get any sound.
Hope you guys have any idea what I could do. I already reinstalled the drivers, switched to microsoft standard drivers, tryed line in instead of mic in port.
I ma using a Maximus V Gene.
Thanks in advance
https://linustechtips.com/topic/598826-modmic-40-problems/
Lets start with the basics. Is it in the right port? PCs usually have one for audio and one for mic. Next check from the recording devices tab if its set to be the default device, if you cant see it the right click and click "show disabled devices". If you cant see it at all in then try another device in the same port if you have one and see if its appearing there either.
Winning an argument with a woman step by step
step one - talk to her
step two - fight with her for 2 hours even if you are really right
step three - admit that she is right for the sake of your safety
step four - realize that you have accomplished nothing and she still thinks you were wrong and now she thinks you are even more stupid
GTX1080ti, I5-4690k, ASUS Z97 PRO-GAMER, 8GB DDR3 1600mhz, Hyper 212 EVO, Tt view 31 RGB.
https://linustechtips.com/topic/598826-modmic-40-problems/#findComment-7774595
My friend had a similiar problem but if i remember correclty it started working a week after it or so after he installed some updates. Have you tried downloading latest drivers for your soundcard?
https://linustechtips.com/topic/598826-modmic-40-problems/#findComment-7774660
