So im trying to get a new case to replace my current one , but im not sure what open air case that is horizontal is a good option, my current cooler is a nxzt kracken x61, and i have a atx motherboard, i was thinking of the thermal take core p5, but it aparently has no liquid cooler support, so what do you all reccomend, or if i should change my cooler, what replacment cooler and case would be good? preferably black in color
Its a Championship not a Belt!
https://linustechtips.com/topic/598572-horizontal-open-air-case-help/
You want your motherboard horizontal? Is that a must?
I'd check out a testbench then, of which LTT has a few reviews on their channels and I know people like InWin do them. Alternatively if you want an ATX-compliant motherboard with very good airflow (that could be placed horizontally too), The Corsair Air 540 is probably your best mainstream bet.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
open air horizontal case?
do you mean a test bench?
i guess i need to find a test bench style case.
8 hours ago, The Elder Smurf said:
It has a front mounted 280mm mount
it states right on the web page that its only a 240mm mount. literally the 15th word in the product description on coolermasters website.
20 hours ago, lilkuz2005 said:
i see no point in that coolermaster case, may as well buy a standard case
no one is buying it , i was stating its like what i was looking for, but it didnt have cooler support.
