3 minutes ago, Chaicho said:
My friend wants to overclock his fx6300 and we dont know what is the best cooler for his build.
he has a gigabyte k78lmT, and a 750ti if that matters
thanks
Tell you friend that he's going to blow something up by trying to OC an FX with that mobo. Stop him at all costs.
Just now, g12601 said:
Get the Corsair Hyper 212 EVO, its cheap and really good.
*CoolerMaster, not Corsair.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/597971-best-cpu-cooler/#findComment-7765108
The 212 evo is pretty dang good for the price.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/597971-best-cpu-cooler/#findComment-7765130
Just now, Chaicho said:
What cheap mobo would you recommend for him to do an overclock?
I would recommend against changing any parts, simply because that money could be spent on a new system.   A Cryrorig H7 would do very well and outperforms the Hyper 212 by some margin.  (plus it should look better)
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/597971-best-cpu-cooler/#findComment-7765144
At least one with a 970/990 chipset.
But if you were willing to get a new mobo + cooler, you might as well use that money + the money from selling the FX to get a second hand i5 4440/4460 + h81 mobo and get much better performance, without even needing to OC.
https://linustechtips.com/topic/597971-best-cpu-cooler/#findComment-7765147
