Hello. I have been getting some nasty glitching sometimes resulting in blue screens or instant reboot on the monitor connected to my GPU.
The monitor i have running on my Internal GPU on my CPU is fine but Windows freezes up so i have to hard reset.
It happens when i put any kind of load on the card, i've attached some pictures so you can see what it looks like.
I have since removed the card and im only running on my Integrated Graphics right now and it hasn't happened since.
Im just wondering if it's safe to assume my card is dead so that i can buy a new one instead.
Thanks.
Edited by vivalacamo
https://linustechtips.com/topic/597859-possible-dead-780/
Try running DDU and re-install the drivers. This can pop up when you have a corrupted driver.
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
https://linustechtips.com/topic/597859-possible-dead-780/#findComment-7763657
1 minute ago, vivalacamo said:
Okay i will do that now. I'll come back with how it went!
Good luck, just keep in mind that there is always the chance that the card is bad as well. Don't want to get your hopes up too much... but fresh drivers have been known to fix this BSOD.
https://linustechtips.com/topic/597859-possible-dead-780/#findComment-7763676
Once you reinstall your drivers, any OC should be gone but you know...was gonna ask, do you have the card OCed at all? Cause arifacting and BSOD could have been caused by a horrible overclock :P
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/597859-possible-dead-780/#findComment-7763685
10 minutes ago, vivalacamo said:
I had it running a slight overclock for about a year stable but as soon as i got this i turned it down to stock again.
Fair enough :P (you forgot to tag/quote me :(, it's all good however)
https://linustechtips.com/topic/597859-possible-dead-780/#findComment-7763800
Just now, vivalacamo said:
Sorry, im alternating between posting on my mobile and using my computer :$
Fair enough :P I don't really mind it so it's all guld :D
https://linustechtips.com/topic/597859-possible-dead-780/#findComment-7763815
Alright so i ran DDU and rebooted into safe-mode and ran it.
Then i tried reinstalled the nvidia drivers and it started artifacting diring the install. Screen got black and computer rebooted.
Now i've got the drivers installed and it looks like this with the correct resolution set.
I guess it's pretty safe to assume it's dead?
https://linustechtips.com/topic/597859-possible-dead-780/#findComment-7763932
