I want to go from my i5 to an i7 as I'm getting bottlenecked in 4X games. With Kaby Lake coming later this year I'm thinking of moving to that. Since they are using the same 1151 socket Skylake is does that mean I can just take my Skylake out and put in a Kaby Lake?
I spend too much on my PC. Then I spend even more on my Sim Rig. Damn, this stuff's expensive.
If your mobo is Z170, yes. Otherwise, current info says no.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
2 minutes ago, thatguyyouknow75 said:
What games do you think an i5 4690k is limiting you in?
*6600k which is even slightly better :P
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
He has an i5 6600k.
CPU AMD Ryzen 5 5700X3D | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G
Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GBPrograms: Samsung 990 PRO 4 TBData: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W
Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming
Sound Card: Creative Sound BlasterX AE-5 Plus, System: Edifier R1280DB | Magni/Modi Schiit Stack  | OS Windows 10, 64 Bit
What they said about the 6600k. Games like Civ BE are known to be CPU limited. My understanding is thousands of units movements being calculated is hard on a CPU.
Sometimes a BIOS update is needed to support CPUs released after the motherboard, and depending on the motherboard manufacturer it might require an originally compatible CPU in order to perform the BIOS update in the first place. But if you are upgrading a Skylake processor to the next generation that shouldn't be a problem.
Probably the GTX 970 limits you way more than the i5 6600k
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
I'm getting a 1080 so that's not going to be an issue for any gaming much longer. But Civ BE is known to be CPU limited. In benchmarks same generation i5 vs i7 the i7 always in Civ.
Not really. The difference is very small on that game. Almost non existent.
It really depends upon what games you are playing, but in general, I don't think you'll see much difference by going to an i7 over an i5. Most games won't use the extra threads. You might be better off to get a GTX-1080 or 1070 instead.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
