Need a hand with Fallout..
Solved by HelplmChoking,
20 minutes ago, VredinLad said:You should be able to complete the quest through the command console just like in skyrim. Try finding the right command line on google, but I doubt you can find the NPC's ID (or the quest ID) since the game isn't officially released yet.
Managed to track down the ID thing, had to list all current quests etc. Advancing just broke it, but I figured it out anyway ![]()
