So i wanted to host a LAN party at my house for 3 people, but I don't know if my wifi can handle it. I know my wifi is dual band, and my router is a Verizon quantum gateway. I read something about port fowarding on game forums, but I'd rather not do that, mainly because i have no idea what it is. I am a complete noob when it comes to networking, so try to explain like you would to a 5 year old. Thanks in advance!
https://linustechtips.com/topic/597139-lan-party/
a 3 person LAN party shouldn't put  much strain on, if you think it might, grab yourself 3 Ethernet cables and plug directly from the router to the PC's
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/597139-lan-party/#findComment-7755526
Pick up a 5 or 8 port switch like this:
http://www.newegg.com/Product/Product.aspx?Item=12K-008X-00026
Hook everyone up to the switch using ethernet cables and then run a cable from the switch to the Verizon router so you all have internet access.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/597139-lan-party/#findComment-7757139
I have no idea how to reply on this forum, so I'll just do it here.
@riley mclinn a lan party is when you have multiple people playing together on the same network
@lurick do i absolutely need one of those switches? I havnt checked, but i think my router has enough ethernet ports for all 3 of us.
https://linustechtips.com/topic/597139-lan-party/#findComment-7760765
To reply, click on the arrow that kind of swooshes up and points to the left.
You don't need a switch if you have enough ports on the router for everyone but if you're far away from the router it can mean just running a single long cable instead of several.
Prior Build Log/PC:
https://linustechtips.com/topic/597139-lan-party/#findComment-7760808
Well the router is going to be right next to us, so it'll be fine.
Thanks for your help though, appreciate it.
https://linustechtips.com/topic/597139-lan-party/#findComment-7760812
Yah, if the router will be right next to you guys then just hardwire in with some cat5e cable, wifi and gaming generally don't do well under heavy load =/
Prior Build Log/PC:
https://linustechtips.com/topic/597139-lan-party/#findComment-7760814
