1st ever Build, Please Help
Go to solution Solved by Vercii,
6 minutes ago, Pullblanc455 said:
This is my 1st Ever PC build ever, i know some basic info on how to build it.. And not only do I want to build it to use it but, its something i want to accomplish.. I need your help if possible.. i want it for gaming but also want it to do regular work.. I have about $600 to $700 dollar budget.. i could go more but i also need to buy the monitor and keyboard ect.. Please help me choose parts and or direct me to a list.. thank you.. and btw i was thinking of a i5 6600k processor to start.. anything else i have no idea..
Eh?
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($169.89 @ OutletPC)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($43.88 @ OutletPC)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR3-1600 Memory  ($27.89 @ OutletPC)
Storage: PNY CS1311 120GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($46.98 @ OutletPC)
Video Card: EVGA GeForce GTX 960 2GB Superclocked Video Card  ($173.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.98 @ Amazon)
Monitor: Acer G227HQLbi 60Hz 21.5" Monitor  ($85.98 @ Newegg)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($28.99 @ SuperBiiz)
Total: $752.55
Generated by PCPartPicker 2016-05-15 15:25 EDT-0400
https://linustechtips.com/topic/596458-1st-ever-build-please-help/
is the $600-700 budget for PC only with no monitor/mouse/KB ect.?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
He said he wants peripherals.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
So:
1.  The tower/PC
2.  Monitor
2.  Keyboard/mouse?
3. OS (Windows)
4. Speakers/Headset?
...and the total for any/all parts needed please.
The 6600K, done properly, will be too much for a $700 budget.  This is without a power supply, storage drive, case and GPU:
$464
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($244.99 @ Newegg)
CPU Cooler: CRYORIG H5 Universal 65.0 CFM CPU Cooler  ($58.02 @ Amazon)
Motherboard: Asus Z170-E ATX LGA1151 Motherboard  ($88.98 @ Newegg)
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  ($64.88 @ OutletPC)
Total: $443.87
Generated by PCPartPicker 2016-05-15 15:31 EDT-0400
Quote
That doesn't mean it has to be included in the budget :P as he states that he prefers for it to be under so he has enough monies to buy the peripherals :D
Eh?
Total: $752.55
Novus Anima
Laptops
Surface Pro 3
Go for at lest a quad core CPU, AMD or Intel.
GPU what ever offers you the best performance or is on offer at your local PC shop.
The mother board will be what ever socket the CPU is , ie LGA 775.
The case depends on if you want to water cool or just use air, Aesthetics or performance, The cooler master case are the best for both worlds
A ssd with at least 80GB of storage and a mechanical drive if you are going tho have lots of photo etc
the power supply will just be what ever has all the right connections on it
Keyboard and mouse what ever you find comfortable to use personal i use a £2.50 USB mouse and a £5 keyboard that has lasted me for 4 years.
Monitor go for the size you like and has the right inputs for your use
Edited by fixitnow
Accidently pressed save while trying to go to another application
Have you tried turning it off and on again?
10 minutes ago, Pullblanc455 said:
The 600 to 700 dollar budget is only for the case and everything in it.. the monitor, keyboard and mouse are off the list.. ill figure that out with time
I know it's slightly overbudget but oh well :P
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
Motherboard: MSI B150M Pro-VD Micro ATX LGA1151 Motherboard  ($49.99 @ Micro Center)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($26.99 @ Amazon)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($33.99 @ NCIX US)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($287.10 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($34.99 @ Micro Center)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($53.99 @ Newegg)
Total: $714.02
Generated by PCPartPicker 2016-05-15 16:17 EDT-0400
(p.s. if you do end up deciding to get a 390, wait for the benchies for the 1070 before jumping on it as it could be a lot better or about the same but no matter what, it will lower the prices for 390 so yeah :D)
$682:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.89 @ OutletPC)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard  ($54.99 @ Amazon)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2133 Memory  ($29.98 @ Newegg)
Storage: AMD Radeon R3 240GB 2.5" Solid State Drive  ($58.54 @ NCIX US)
Video Card: PowerColor Radeon R9 380X 4GB PCS+ Myst. Edition Video Card  ($223.98 @ Newegg)
Case: Thermaltake Versa H22 ATX Mid Tower Case  ($34.98 @ Directron)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($67.49 @ Amazon)
Case Fan: Kingwin CF-012LBR 40.0 CFM 120mm  Fan  ($3.98 @ OutletPC)
Total: $672.81
Generated by PCPartPicker 2016-05-15 17:25 EDT-0400
