I had too reinstall windows since i first installed pro but after i while i discovered that to me it was definetly not worth twice the prize, but now that have deleted everyting on the computer and made a usb stick boot device. i put it and nbothing happens i try many times without luck. and i try to go in to bios multiple times until it finally worked then tried to change first boot device to usb stick. it worked but after the installation of it was done and the blue windows logo and loading screen came it stopped and went to the start i tried multiple times to install it again and again and nothing else happend. I try to make a usb 2.0 stick to boot device and tried to boot with it but now it is not even detected i have tried all usb ports on the computer and nothing works. Please help how can i get my computer to work again i want to install windows 10 home. Sorry for my bad english, english is not my mother language
https://linustechtips.com/topic/596445-help/
