So lately my amd a8 6600k has been overheating. i still had the stock cooler so i bought an artic freezer pro 7 rev 2 however it is still hanging around 60c and 80c. It overheats whenever i try to play a game and sometimes reaches 100c when i render videos. Is this a normal thing for my cpu or do i have a dodgy chip?
https://linustechtips.com/topic/596345-a8-6600k-overheating-issue/
I saw a post on reddit a while ago where someone's H110 fans weren't spinning. Make sure your fan is spinning.
i5 6600K @ 4.4GHz / Cooler Master Nepton 240M (GC Extreme Thermal Compound) / Asus Maximus VIII Gene / 8GB Corsair Vengeance LPX DDR4-2400 / 240GB SanDisk SSD Plus & 2TB SeaGate Barracuda HDD / EVGA GTX 980 ACX 2.0 / XFX XTR 750W 80+ Gold  / Fractal Design Node 804        Total: £1042.31
Listen inside the case and make sure your pump is running. If it's not, RMA. If it is, remove the cooler, clean all the paste off with isopropyl alcohol, then reseat the cooler with new paste. Make sure it's got a firm, even connection with the CPU all around.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
just to clarify i have an air cooler
D'oh. I saw H110i and assumed that's what you had. My bad for forgetting the OP.
Reseat the cooler. If that doesn't fix it, consider the following questions:
-What were your temps on the stock cooler?
-Were you overclocked on stock, or is that a new thing on the Arctic?
Regardless, your idle temp is way too high, which makes me suspect that the cooler isn't mounted properly.
ok i will get some thermal paste and reseat it tomorrow
Don't you have any left?
Reset your BIOS. Transient spikes on power line, and other odd circumstances can result in some BIOS settings getting change. It could be that your APU is running out of spec - wrong frequency or voltage, for example.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
i just reset my bios and it hasn't made a difference, thanks anyway tho m8
i have reseat the cooler and it hasnt made a difference, nor is it overclocked. the temps on my old stock fan were 70c-85c. Is there anything else or should i just get a new cpu
Have you tried many different monitoring tools? Maybe that specific program you used displayed the wrong temp.
CPU: Ryzen 2 2700@ 4.0Ghz    Mobo: Gigabyte X470 Gaming 7 Wifi    Cooler: EVGA CLC 240    GPU: GTX1080 FTW DT @ 2113Mhz   PSU: EVGA 750W P2
Case: Fractal Design Meshify C   Displays: 34" LG34UC79G, 24" Dell
i have used speccy which gave 60c-8c, i have used AMD Overdrive which gives about 50c and Speedfan which gives 30c. My pc always turns its self off while i play games because of it overheating and thats why i want to fix it
