So I am about to buy the Phantek P400S case. I am making it as quiet as possible as it will be on often.
The case has everything I need for a great price. But I was wondering whether or not I am gonna need to purchase more fans for the case.
I will be running 1 single 1080 (Once released) and my I7 4790k (Overclocked to around 4.4Ghz). I will also be upgrading my PSU to CM RM750X at the same time.
There will be no top fan's, I do have 4 Corsair AF120's, are they good enough? I have about £50 to spend.
Questions:
I have 4 Corsair AF120 Quiet edition fans brand new in a box, Could I use these in the case or should I buy new fans and sell the AF120's?
What would the best setup be for the fans?
PS. Let me know if you need any more information I will for sure be able to provide it, and thank you for all your help.
https://linustechtips.com/topic/596048-help-for-case-fans/
cooling will probably be fine, and those fans would work fine, when it's set up test with the two it comes with, try it with 2 more and see what happens, but I would advise figuring out some kind of filtration on the front panel intakes to help limit dust build up.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/596048-help-for-case-fans/#findComment-7745655
Ok, will look into that, I can do a couple of stress tests to look at temperatures which will be ok.
https://linustechtips.com/topic/596048-help-for-case-fans/#findComment-7745658
Your current cooling is enough. Whether it's too loud or not is up to you.
https://linustechtips.com/topic/596048-help-for-case-fans/#findComment-7745777
