Hi, I have a problem with MSI Afterburner custom fan curves. Those are working only when I open the MSI Afterburner. If I am closing it, fan curves go back to stock. Apply at windows startup is checked, the overclock settings load at startup and works if I close MSI afterburner, but the custom fan curves settings go back to normal. Is this normal? Is there any solution for this? I have to run MSI Afterburner in background for custom fan curves settings in order to work?
https://linustechtips.com/topic/595442-msi-afterburner-problem/
Don't close it. Software needs to be running. If its not, windows (or GPU BIOS) can't tell if you have done anything or not. From settings tick checkboxes which say minimize on tray when closing. This way it stays open at background. Also, apply on windows startup for OC changes GPU BIOS settings directly. For fans you need to have software to load when starting windows.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/595442-msi-afterburner-problem/#findComment-7742049
