This is going to be my first camera. Video is going to be my first priority, but I don't want to skimp out on image quality either.  DSLR or mirrorless is okay. I'll only be using the stock kit lens since this is just for schoolwork and casual photography. Thanks!
https://linustechtips.com/topic/595357-good-first-camera-for-around-500/
I quite like the Panasonic LUMIX G7, but you might want to give a bit more info like: what kind on environment you'll use it in, what you'll be filming, how important are future upgrades, what connectivity you want, is form factor important to you?
Does you mum know you're here?
If you are buying a DSLR and never intend on upgrading from the Kit Lens, just dont bother buying one
better off getting like an RX100 or RX10  (or equivalent)
Yes, I have seen the G7, but unfortunately, it's not available in my country (Philippines).
1. ?
2. I'll be filming short clips like music videos, infomercials, etc.
3. Not important. What I'm gonna buy is what I'll use. I'm not that into learning photography, I'm still a student.
4. ?
5. Nope. As I said, DSLR or mirrorless.
16 minutes ago, djdelarosa25 said:
I won't be needing 4K. 1080p 30fps is enough.
Maybe the Sony a5100? Great camera, compact, easy to use and pretty versatile
The Nikon D3300 is also a great camera to start with, and quite a bit under your budget.
Thanks for the suggestions. The D5300 and 700D/T5i are also within my budget.
Which do you think is a better road, DSLR or mirrorless?
For video id say mirrorless, for stills, either
though both can do both
(wow I hope that made sense)
Both can do the job just fine. Mirrorless cameras are usually more compact and maybe technically more advanced.
Although sometimes a cheap DSLR can give you a bit more than a budget CSC. Also, battery life is generally better on DSLRs.
I know, not really making it easier here xD
If you were me (lol), what would you choose?
A5100 vs D3300 vs D5300 vs 700D
Sony A6000
3 minutes ago, djdelarosa25 said:
Out of my budget here in the PH.
Ah, you said $600.. so I was assuming $600
its utterly pointless giving youd budget in USD
Under 600 USD.
So in PHP it's under 30,000.
Well the A6000 is $599 in the US.... haha
1 minute ago, djdelarosa25 said:
Damn haha. Well, out of my choices, which one would you go for?
Or you can recommend something in the $500-550 range just to be safe.
How much is it there? have you looked into it?
I guess if you could link me to a few stores there I could have a look
SRP is PHP 34,999
http://www.henryscameraphoto.com/store/sony-a6000-black-w-e-pz-16-50mm-f35-56-oss.html
Cheapest that I could find after hours of researching. Unfortunately, my mother's not in a good spot for cash right now, since it's back to school and she has to spend loads on my siblings, too. So the hard cap of the budget is PHP 30,000.
Professionally or as a hobby?
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
5 hours ago, djdelarosa25 said:
As school projects haha. Of course, as students, our teachers don't expect us to be pros when it comes to filming.
OK, I just wanted to clarify.  In this case the cameras that others have recommended are good.  It's not necessary for me to get involved.
panasonic g7
