24 minutes ago, Jossh said:
Hi i want to build a new pc but a compability check says that my cpu, the AMD A8-7650K and my motherboard ASRock FM2A88X Extreme4+ ATX FM2+ Motherboard are not compatible when the motherboard and cpu have the same socker, FM2+, can you help me plssssssssssssss
I do believe that that combo is compatible! Sometime PC Picker is not always right, check on the MB website and see if maybe the BIOS does not support the chip for whatever reason the MB manufacture will tell u if it does not!
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
the BIOS could be outdated. that's why it says it's not compatible
its one of several things, BIOS outdated, the Socket itself (FM2 and FM2+ aren't that reliable) or the power supply you are using isn't providing proper current to the CPU, with the Power Supply being the most unlikely culprit, i would recommend updating the BIOS, and if that doesnt work
and the note from PCpartpicker.com states:
  • Some AMD A88X chipset motherboards may need a BIOS update prior to using Kaveri CPUs.
