Even after weeks of research an forum articles i am still not shure what type of cooler to use... Here's my build: http://de.pcpartpicker.com/p/YqmWYJ
Here are my pros and cons so far:
Water
  • looks nice (+)
  • costs more (-)
Air (would buy the Nh-D15)
  • costs less (+)
  • less noise (+)
I am not sure which cooling method is more efficient, please help me out and give me tips!
Yours pluppy
NOTE: YES I'LL WAIT FOR THE 1080!
https://linustechtips.com/topic/595034-cooling-my-cpu/
Water
  • looks nice (+)
  • costs more (-)
  • costs less (+)
  • less noise (+)
Yours pluppy
noctua ftw
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7734758
1 minute ago, roughavoc said:
As another member said, hold off on purchasing that GPU for at least another week for the 1080 reviews to come out.
Or just get a 1080, even if it doesn't perform that much better than the 980ti, it's still less expensive.
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7734789
Water coolers can be quiet as well, especially if you stick some NF-F12s on them (although raising the cost even further). The only concern is pump noise but that's never been a problem for either of the coolers I've used (H100i and TD02-LITE).
I personally prefer AIOs for build aesthetics, ease of install, and more common case compatibility (well, versus the NH-D15), but I'm a bit more of a "form over function" kind of guy. Either way you go is purely preference, the NH-D15 is a very solid air cooler, matching high-end AIOs, but as far as aesthetics, AIO has that contest hands down.
1 minute ago, pluppy said:
no no no! 980Ti ~650€ | 1080 min 700€
If not the 1080, then the GTX 1070 is supposed to outperform the GTX 980 Ti and almost half the retail cost and significantly lower power consumption. That leaves you with money to save for SLI or to pour into the remainder of the build, such as getting a couple 3TB HDDs for redundant storage.
if you have to insist you think for yourself, i'm not going to believe you.
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7734820
Watercooling adds point of failure. Go for Air cooling with fans in push-pull configuration... Even if one fan fails it will still operate at near peak efficiency!
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7734841
Noctua of course!
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7734843
46 minutes ago, pluppy said:
no no no! You've forgot that i am not in the US! German prices:  980Ti ~650€ | 1080 min 700€
980ti=$650
1080=$600
Not sure where you got that price for the 1080. Also, see next multi-quote.
This.
More points of failure, yes, but it only really matters if you get an AiO from an unreliable company. Corsair, the Kraken x61, the new EK AiO's, etc., all highly reliable with bulletproof review's, and outstanding customer-support.
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7735043
Just now, positivePXL said:
980ti=$650
1080=$600
This.
Definitely but if you want the UTMOST in reliability air cooling is the way to go
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7735053
Example one:
You are using an air-cooler, you have an overclocked i7-6700k, you're gaming, your cpu is running at 80-85 C^o.
In this example, your cpu dies in a few years, maybe even a few months if it gets hotter, but hey, at least your air cooler was reliable!
Example two:
You are using a water AiO cooler, same overclocked i7-6700k, you're gaming, your cpu is running at 60-65 C^o.
In this example, your cpu runs long enough that your cpu lasts almost a decade and is still running strong when you hand it down to your son/daughter before he/she breaks it in the first month of service, aren't they cute? Somewhere along the line, one of the fans on your Corsair H100i GTX radiator stops spinning, you noticed it when you turned on your computer one day and didn't see it spinning. You had to replace the fan, oh well.
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7735117
1 hour ago, positivePXL said:
Example one:
Example two:
You're right, air coolers are just decent for stock speeds and nothing more...
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7735531
15 hours ago, aisle9 said:
Post = over
Credibility = very zero
It's not like he was trying to save a few buckets by going with a 6700, a 6600k, a 6600, or even a 6500. He allotted for an i7 6700k, the most expensive Skylake chip on the market. I refuse to see how my credibility is very zero all things considered. If you really want to take care of your system, and you still want to overclock, liquid cooling is the most efficient manner by which to do so, I'm sorry if you see it otherwise.
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7738462
18 hours ago, positivePXL said:
980ti=$650
1080=$600
My prices are right since i am NOT from the USA! I am in Germany and here the founders edition is released at May the 27th for over 700€ due to the taxes etc. 1 or 2 months there may will be some reference models out for over 600€.
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7738490
You might only be looking at "Founders Edition" Cards, otherwise, the 980ti has fallen a lot more in price in Germany than it has in the US, otherwise, all parties considered, the 980ti is more expensive than the 1080.
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7738512
19 hours ago, positivePXL said:
Example one:
Example two:
Get a high end cooler and that won't happen lol
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7738699
3 hours ago, Nacho Marco Segui said:
Really, hope it is sarcasm
Of course it is! If you buy one of sufficient quality (e.g. Noctua) it will definitely outperform a lower-end water cooler,but not a custom loop. AND if your PUMP and not your fans fail you ain't gonna notice anything and end up killing your hardware... AiO liquid coolers have a very short lifespan btw...
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7739526
Only if it is not a quality OEM, such as Corsair or NZXT.
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7739716
Well... Depends... If you are going to spend $100-200+ on an AiO Liquid Cooler, it shouldn't fail (unless defective). But the cheap, 50-70 dollar-ish, ones are NOT as reliable as an Air Cooler of the same price...
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7739785
Not to mention that they might even have worse performance!
https://linustechtips.com/topic/595034-cooling-my-cpu/#findComment-7739804
