I have a 390 and am wanting to get a 144hz monitor because I mainly play fps games. I know that BenQ is trusted and awesome. But I found an AOC monitor that has free sync ontop of being 144 hz and it costs less. I am talking about the AOC G2460PF (http://www.amazon.com/AOC-G2460PF-24-Inch-Gaming-Monitor/dp/B01BV1XBEI/ref=cm_cr_arp_d_product_top?ie=UTF8#Ask) and the BneQ monitor that im also considering. The BenQ XL2430T (http://www.amazon.com/gp/product/B00ITORITU/ref=s9_al_bw_g147_i1
Is freesync worth it at 144hz? or would you go with the better build quality. Let me know what you would go with and why. Thanks! :D
https://linustechtips.com/topic/594826-freesync-vs-build-quality/
8 minutes ago, BunnyHunter67 said:
they are tn panels. they wont look very good anyway. i would go for the cheaper one.
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
