So I just sold my fx 8150, Crosshair V motherboard, and my xfx 7970 and I got $305, which i was hoping to buy a new Cpu, Ram(If its DDR4) and motherboard.
I have $305 right now, but I could probably get around $350-400 within the next week. What is the best processor and motherboard I can get or DDR4 if its skylake?
I was thinking a 6600k to oc because Im going to be getting a gtx 1080.
 What motherboard would pair well with that for overclocking, sli (Would be a big plus) , nice features,
and thats not super expensive? also what ddr4 is good for gaming and is red or white?
Also if there is a better cheaper option like an older i7 or xeon let me know because I have 16gb of DDR3 Waiting here
Thankyou for any help
https://linustechtips.com/topic/594761-6600k-upgrade-help/
You kinda wasted your money a bit... sure, the 8150 isn't that great of a CPU, but I would have waited a little longer before upgrading it.
Still, get yourself a 4770k / 4790k with a Z97 mobo. That's what I would do.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/594761-6600k-upgrade-help/#findComment-7731848
Im getting a gtx 1080, which would of been majorly bottlenecked
https://linustechtips.com/topic/594761-6600k-upgrade-help/#findComment-7731858
Yes, I know. But even then, I would have held of upgrading the CPU, in antecipation for Zen or Kaby Lake.
Trust me, I used a 970 2 months after launch with a 2.4ghz triple core 1st gen APU for more than a year, as I waited for Brodawell... until Intel trolled all of us and I decided to aim for Skylake. And I don't regret it one little bit. Even with the bottleneck, you should have waited.
No point in complaining about spilled milk, though...
https://linustechtips.com/topic/594761-6600k-upgrade-help/#findComment-7731881
I dont see what is the issue of getting the 6600K
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($233.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: MSI Z170A KRAIT GAMING ATX LGA1151 Motherboard  ($132.98 @ Newegg)
Memory: Kingston FURY 8GB (2 x 4GB) DDR4-2400 Memory  ($32.99 @ Amazon)
Total: $424.85
Generated by PCPartPicker 2016-05-11 22:45 EDT-0400
here is a general price of the reasonable parts for 6600K with mobo and RAM
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/594761-6600k-upgrade-help/#findComment-7731901
the 6600K should not have issues and if the 6600K bottlenecks the GTX1080
then any CPU lower than it will be a major bottleneck
https://linustechtips.com/topic/594761-6600k-upgrade-help/#findComment-7731902
11 minutes ago, Dark_Fuzzy said:
If you have some decent ddr3 laying around just get a 4790k or even a 4690k. Not enough of a performance difference to pay more for skylake.
Really depends on what the price difference is; in Canada it's a $5 difference between the i7s and $10 difference between the i5s. Right now you can probably sell the 16GB DDR3 for a decent price and buy DDR4 without losing too much money; 16GB of DDR3 will go for about $65-70 here and decent 16GB DDR4 ram is about $75.99. I personally wouldn't mind spending an extra $20 now to go skylake over haswell but again all this depends on what the price difference is where you live between the two architectures. If you are looking at a difference of $60 or more, than as Dark_Fuzzy said, its better to go Haswell.
https://linustechtips.com/topic/594761-6600k-upgrade-help/#findComment-7732208
17 minutes ago, Shura said:
snip
Exactly, if the price difference is $50 or $60 it can be used on other components in the system with no real performance loss.
But if there isn't really a price difference go Skylake.
I know when i built mine back in January i got a 4690k for $180 used compared to $230 new or $260(i think) in some places for Skylake. Plus the board and ram were much cheaper(already had ddr3) So i was able to get a 4690k,z97 mobo,and a Cryorig h7 for $350 compared to close to $400 if i went with skylake.
https://linustechtips.com/topic/594761-6600k-upgrade-help/#findComment-7732238
