Need Help with Creating Java Methods
Go to solution Solved by HPWebcamAble,
Just now, IvanSnipedYu said:
It gives me a compilation error. I just noticed the thing you were pointing out. I changed it but now I get no output.
You mean mean it doesn't tell you the result?
You need to ask it to print to the console.
Here's the method to do that:
system.out.println( "<something to print>" )
I'm trying to learn creating java methods rn but for some reason I can't get something like this to work. Can someone please explain to me what I did wrong and how I can fix it.
import java.util.Scanner;
public class HW06P01 {
	public static int findTerm(int n){
		int result;
		result = ((n(7*n-3))/5);
		return result;
	public static void main(String[] args) {
		int a = 1;
		findTerm(a);
| i7 4790k | H100i | 16GB (8x2) Corsair Vengence | EVGA GTX 780 SC | ASUS Z97 Sabertooth Mark I | Samsung 840 120GB | WD 2TB Green x2 | Rosewill Hive 750W |
https://linustechtips.com/topic/594713-need-help-with-creating-java-methods/
What's wrong exactly?
Just guessing, I'd say this:
Needs another multiplication symbol, like this:
result = ((n*(7*n-3))/5);
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
