1 minute ago, Bobbysonators said:
Could I run the low profile n-vidia Geforce gtx 750 (not Ti) on a 240 watt power
supply? Its priority with no upgrade need help on this ASAP. Thanks for any help.
you might be able to run the 750... What CPU? If its a low power cpu like the pentium then maybe. As long as the card doesnt have 6 pin power then yes. It should run, but i would recommend upgrading the PSU ASAP
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/594175-help-me/#findComment-7725382
even getting an Evga 430w White rated PSU would be better than that 240w...that's the lowest of the lowest I would go and they're not even that great...
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/594175-help-me/#findComment-7725403
Its a core i5 3470 which consumes a decent chunk of the power I could get a Pentium and get a gtx 750 but I want to run forza 6 which which the Pentium couldn't do
https://linustechtips.com/topic/594175-help-me/#findComment-7725410
wait wait wait..... You have the i5 already? Why not do this, get a 750 ti and buy an evga 430w. Can you do that?
https://linustechtips.com/topic/594175-help-me/#findComment-7725412
I do have a 405watt enermax tomahawk but like I said it's proprietary
forza 6 with an i5=no chance with only 240w...(also, you never mentioned you had a 405w enermax PSU...so we didn't know you had that PSU at all...)
https://linustechtips.com/topic/594175-help-me/#findComment-7725425
