Fan Combos
Noyu
So I plan to transfer my build (see sig) to a Thermaltake Versa H15. In addition I will be installing a DeepCool Rock Master v3 upfront
For air cooling I will have:
2x Scythe Gentle Typhoon 1850RPM (DC)
1x Pre-installed Fan on CM Hyper 212x (PWM)
2x Pre-installed Fans on BitFenix Phenom M (DC)
1x Pre-installed Fan on TT Versa H15. (DC)
What do I do with them? So many faaanssss
My initial idea would be to,
  • push/pull the 212x with 2x BitFenix Fans
  • front intakes with 2x Scythe GTs - spotcooling GPU and HDDs no?
  • back exhaust with 1x TT Fan
  • top intake with 1x CM Fan (on the slot nearest to front)
But I already know that this is bad since I'm using the wrong fans on the wrong services.
So, thoughts?
Karamo
CPU: AMD Ryzen™ 5 3600 | CPU Cooler: Wraith Stealth | GPU: Gigabgyte AORUS GeForce RTX 2070 Super | Motherboard: MSI B450M Mortar Max | RAM: G.Skill FlareX 2x8GB 3200MHz CL16 | SSD: ADATA XPG SX6000 Pro M.2 256GB | HDD: 1TB 2.5" Western Digital Blue (WD10SPZX) | Case: NZXT H510 | OS: Windows 10 Pro 64-bit |
1 minute ago, Nacho Marco Segui said:
It does not matter much to be honest, but the configuration you have suggested looks nice
My only "doubts" about this is the performance of the push/pull BitFenix Fans vs the 1x CM Fan
Karamo
Two fans will perform better, I think. You could run Aida64 with both configurations and see which one is the best.
