Overclocking help
14 minutes ago, JonaChan said:I have a hyper evo 212 on an fx 6300
Running on a Msi970
Looking to overclock so it will bottleneck a gtx 1070 as little possible till i can afford a better am3+ cpu. Anyway, i am new to overclocking, and am inexperienced with click bios 4 so steps for overclocking step by step are needed. I am wanting to hit 4.5 or 4.6 on my cpu but do not know if i got lucky enough to get that high at good temps. VERY specific instructions to overclock it s͟͟a͟͟f͟͟e͟͟l͟͟y͟͟ little by little with settings until 4.5 would be greatly appreciated. I know im asking a lot, but linus tech forums haven't let me down.I understand that im overclocking at my own risk.
Thanks.
Im not sure how effective it was, but to overclock my 6300 on an Asus M5A97, I just downloaded AMD Overdrive. I got easy 4.5 ghz with that. It will adjust the voltages itself or you can do it manually. I just use the Turbo Core option which is the easiest to get 4.5 ghz.
