so im a youtuber and i want to build a mATX build
im using this case: http://www.parvumsystems.com/product/parvum-systems-s1-0-white (gotta find a way to get it to america)
mobo: Depends whats a good mATX board im using a i7 4770k  (mobo has to have alteast 2 pci slots
GPU: depends on what the good one is at the time
PSU: whats a good psu to run a 770 equivalent card.
HDD and ssd: 500 gig ssd (whatevers good at the time) and a nas system with red drvies., whats a good nas system BTW
all peripherals and monitors and all that external stuff will be chosen by me personally and will consist of whatevers good at the time.
long story short.... whats a good nas system and mobo for lga 1150
Space Journal #1: So Apparently i  was dropped on the moon like i'm a mars rover, in a matter of hours i have found the transformers on the dark side of the moon. Turns out its not that dark since dem robots are filled with lights, i waved hi to the Russians on the space station, turns out all those stories about space finding humans instead of the other way around is true(soviet Russia joke). They threw me some Heineken beer and I've been sitting staring at the people of this forum and earth since.
https://linustechtips.com/topic/59294-mobo-and-nas-help/
https://linustechtips.com/topic/59294-mobo-and-nas-help/#findComment-804660
The ASUS Gryphon motherboard is a good board, I have used it in a couple of builds. Though it is about $160 so if you are looking for a cheaper board you can go with the ASRock Extreme4, which is about $50 cheaper. So you know though, a 770 equivalent GPU could be a 7970 but the 7970 uses more power, but if you meant a GPU that uses the same amount of power you would be looking at something different. And just like above please read the pinned post about posting.
https://linustechtips.com/topic/59294-mobo-and-nas-help/#findComment-806422
