is there a quick way to change resolution and refresh rates
kronickiller
everytime i switch between 4k and 1080p i gotta screw arround with refresh rates
anyway to make this quicker
say 1080p 120hz
and 4k 60hz
it always defaults to some krappy refresh rate when i switch over lol
you switch where? on your screen? what brand/model? Or in a game?
Planning on trying StarCitizen (Highly recommended)? STAR-NR5P-CJFR is my referal link
my windows resolution
i generally keep it at 1080p but ocationally like to surf some youtube or some other thing at 4k
windows 10 makes it a idiotic process to change everything lol
the default for 1080p it sticks me at 30hz interlaced
4k it dumps me at 24hz lol
always gotta up the dam hz when i change
Wtf im afraid I cant help then, never played around with those setting in win10
Checkout QRes, I think it should be able to do this for you. (I may be wrong, I just found it in like 2 minutes of searching).
My Current Build:
Intel i5 3570K @ 4.4GHz 1.11V, Cooler Master Hyper 212 EVO, Asrock Z77 Extreme4, Corsair Vengeance 8GB 1600MHz, Samsung 840 EVO 250GB, Asus GTX 760 DCII Overclocked, Corsair CX600M
You can set hotkeyable presets in the AMD driver
thought they removed that dam hotkey thing been lookin all over for it
will try out qres
Display fusion,
run it at windows launch when you need to swap right click it in the notification area, monitor profile, pick needed one...you are done
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
