Alright, This is the build.
http://au.pcpartpicker.com/p/MjXbsY
Do you guys think I can get the two 120mm radiators in the case? I should be fine but just after some other opinions.
Let me know what you think. Also I will be getting the gear tomorrow so if you have any suggestions just let me know.
Thanks.
I'm afraid to swear now because the overlords might hurt me.
https://linustechtips.com/topic/592797-will-it-fit/
from the website
Quote
Water cooling compatibility (note: not compatible with AIO water cooler units that feature the pump on the radiator):
  • Top – 280, 240, 140 and 120 mm radiators. (Thickness limitation of 100 mm for both radiator + fan) (240 and 280 mm radiators require removal of the ODD bay) (280mm radiator can be maximum 325mm in length)
  • Rear – 120 mm radiator (not compatible with the rear 3.5" HDD position)
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
https://linustechtips.com/topic/592797-will-it-fit/#findComment-7711650
6 minutes ago, Captain_France said:
Well they say that it will fit a 240mm, does that mean I can assume it will fit two 120mm?
If you plan on going custom it will depend on the radiators design. Some have additional material on either side of the mounting holes which would cause them to not line up with the holes on the case if you tried to mount them side by side. Personally I use Alphacool radiators and they don't have excess material running the length of the radiator on the sides so mounting two side by side should be possible, just be careful what radiators you pick.
https://linustechtips.com/topic/592797-will-it-fit/#findComment-7711723
