Alright so ill get right to it i have had issues for the past 24hrs for overclocking my FX-6300 I don't want to hear about how old the processor is and that i need to upgrade i know. But my issue is that it now no longer overclocks AT ALL after i installed a 32g ram kit (4x8g sticks) the brand is vengeance. With my old ram 2 4g sticks of crustal ballistics i was able to overclock my CPU to around 4.4ghz and had great temps. Someone please help me i can take screen shots of my bios settings if needed. If you have any questions for me please comment below.
Parts:
CPU: AMD FX-6300
GPU: GTX 980ti EVGA edition (i dont want to hear about the bottle neck i know)
Motherboard:Gigabyte AM3+ AMD DDR3 1333 760G HDMI USB 3.0 Micro ATX Motherboard GA-78LMT-USB3
PSU: Corsair CX850M
CPU cooler: Cooler Master Hyper D92 - CPU Air Cooler with Dual 92mm Offset Push-Pull Fans and Accelerated Cooling System
https://linustechtips.com/topic/591911-help-overclocking-amd/
4 minutes ago, XBL-Revolution said:
PSU is brand new and like i said it only just stopped allowing ANY overclocking since i installed the vengence ram in quad channel.
maxing out a memory controller is fairly stressful. Try dropping down to two sicks of the 8GB and trying again.
Alternatively reduce your ram speed and try again.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/591911-help-overclocking-amd/#findComment-7702133
Ram speed is at 1333 atm since its a old ish board. Im able to get it upto 1600 without any errors without ocing my CPU.
https://linustechtips.com/topic/591911-help-overclocking-amd/#findComment-7702139
Hmm. Again it is important you try two dimms of the new ram and see if that lets you overclock.
You might have to increase the (aww shit I can't remember what the voltage terms are for FX... I just did this two months ago on a build for my parents...) system agent voltage. (Northbridge?)
https://linustechtips.com/topic/591911-help-overclocking-amd/#findComment-7702147
Parts:
CPU: AMD FX-6300
PSU: Corsair CX850M
You need to up the voltage on your CPU-NB and increase the CPU-NB clock a bit IIRC. That motherboard isn't the best either so watch all your temps.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/591911-help-overclocking-amd/#findComment-7702150
Yes it is northbridge would u like some pics of my bios?
https://linustechtips.com/topic/591911-help-overclocking-amd/#findComment-7702153
CPU-NB and NB voltage.
Chernobyl
Kraken
https://linustechtips.com/topic/591911-help-overclocking-amd/#findComment-7702155
I know every chip is different but do you have recoemnded voltages for 4ghz, 4.2ghz, and 4.4-4.5 ghz? sorry if its to much to ask.
https://linustechtips.com/topic/591911-help-overclocking-amd/#findComment-7702158
Yea look to Benji on this one, I've only dabbled a little bit with FX chips (although I did research at the time, and know general overclocking pretty well.)
https://linustechtips.com/topic/591911-help-overclocking-amd/#findComment-7702169
I haven't overclocked a 6300 manually but when you use 4 dimms on an FX chip the IMC gets hammered hard so increasing your voltages on the CPU-NB will help a lot.
Chernobyl
Kraken
https://linustechtips.com/topic/591911-help-overclocking-amd/#findComment-7702172
Alright thx.
Do u mind ether helping me here on the thread or in PM?
https://linustechtips.com/topic/591911-help-overclocking-amd/#findComment-7702176
Replied to your PM.
Chernobyl
Kraken
https://linustechtips.com/topic/591911-help-overclocking-amd/#findComment-7702203
