Recently my computer has been freezing and when i restart it it has a blackscreen. After that i wait a little bit my computer works and does the same thing and ive gotten a new gpu ram and cpu cooler.
Specs:evga geforce gtx 750ti
psu:cx750m
cpu:phenom x6 1055tt
ram:ripjaws 8gb ddr3
Cpu cooler:cooler master 212 evo
motherboard:Gigabyte (ga-870a-ud3)
https://linustechtips.com/topic/591879-computer-problems/
psu:cx750m
is the psu still ok?
https://linustechtips.com/topic/591879-computer-problems/#findComment-7701715
psu:cx750m
does it freeze when you do anything GPU intensive?
are you monitoring your CPU temps. I know that 212 evo is a bitch to put on make sure your CPU is not overheating. would make sense casue you say you leave it off for a while(giving the CPU to naturally cool down ) then it will work till heats up shut off and repeat.
CPUIntel i5-6600k - Mobo - MSI Z170A M3 Gaming - RAM - 16GB G.SKILL DDR4 2133 -  GPU - MSI R9 380 4GB
CASE - Corsair Cube 540  CPU COOLER - Hyper 212 EVO - PSU - EVGA 1050w
https://linustechtips.com/topic/591879-computer-problems/#findComment-7701721
Yeah my max was 31 degrees celcius
https://linustechtips.com/topic/591879-computer-problems/#findComment-7701763
Looking up reviews on the cx750m, if it gets hot enough it likes to cut current, make sure it's not packing dust in it overheating it
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/591879-computer-problems/#findComment-7701795
psu:cx750m
Are you using the 364.xx or 365 Nvidia drivers? If so, nuke them with DDU and install back 362.00, see if it solves the issue.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/591879-computer-problems/#findComment-7701938
