Im having a few issues with my 960 when trying to overclock, I can comfortable hit +200 on the core and +390 on the memory with stock voltage, however any increase in voltage causes it to crash.
Im also having some issues when turning on my PC and nothing coming up on the screen, my pc boots into windows as the RGB profiles for my mouse load once windows is running and sound plays, this is very annoying as it doesn't always turn on for a few attempts. Do I just have a bad card or is it something else?
Needs money for car parts :P
System specs: Core i7 9700k, Dark Rock Pro 4 , MSI Z390 PRO, 16GB CORSAIR VENGENCE DDR4 3000, ASUS RTX3080Ti, Corsair AX860, Seagate 1TB, Sandisk 240GB SSD, Samsung 1TB SSD, Corsair 400c
My Steam Profile (from SteamDB)
  • Worth: £654 (£221 with sales)
  • Games owned: 62
  • Games played: 52 (83%)
  • Hours on record: 2,980.7h
https://linustechtips.com/topic/591270-issues-with-my-960/
crappy overclocker
https://linustechtips.com/topic/591270-issues-with-my-960/#findComment-7694939
1 minute ago, don_svetlio said:
crappy overclocker
Ive managed to get it to +350 on the core and even something like +500 on the memory but it keeps causing driver crashes. I got halfway thru a benchmark before it did that
  • Games owned: 62
https://linustechtips.com/topic/591270-issues-with-my-960/#findComment-7694948
it's not stable therefore the OC is not good
https://linustechtips.com/topic/591270-issues-with-my-960/#findComment-7694960
I have a feeling thats something to do with stock voltage tho no? Also adding voltage caused it to crash even without an OC
  • Games owned: 62
https://linustechtips.com/topic/591270-issues-with-my-960/#findComment-7694973
8 minutes ago, Allshevski said:
Man, +200 on that card? Could you GPU-z your clocks? Coz +110 on Core and +170 on memory caused crashes on my card..
  • Games owned: 62
https://linustechtips.com/topic/591270-issues-with-my-960/#findComment-7695326
Just now, AlwaysFSX said:
Voltage controller could be junk.
Im putting it down to 2 things, the card sucks, or my psu sucks. Also could either of those be the reasons that it fails to run sometimes on startup?
  • Games owned: 62
https://linustechtips.com/topic/591270-issues-with-my-960/#findComment-7695362
If you can OC it as much as you can, obviously the core in the card is pretty good and the PSU can supply it clean power without it crashing. If it crashes when you try to change the voltage and in no other situation then the voltage controller might just be junk which would also cause problems on startup.
https://linustechtips.com/topic/591270-issues-with-my-960/#findComment-7695379
Like I said earlier, I can get it to run fine for a few mins with an even higher clock, adding voltage causes drivers to crash, ill test it again once I get my 650x and see if that makes a difference.
  • Games owned: 62
https://linustechtips.com/topic/591270-issues-with-my-960/#findComment-7695391
