Taking apart PC for a cleansing
Mohenjo
So im gonna take apart my whole PC and cleanse that beast. I havnt done that in two years. I would occasionally blow out dust but thats it. Got any tips for me? All i know how to use is compressed air.
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
note the screws you separate.
Put all parts on something that isnt moist? Im not sure xD
MY RIG
I5 6600k
16gb Corsair vengeance 2666mhz
MSI Gaming X 1070
WD blue 2tb
samsung 850 evo 250gb
EVGA supernova G2 650w
Depends on your confidence. Always remove the PSU last and leave it plugged into the wall but switched off. This way you can always be grounded. (But you probably knew that from 2 years ago :P)
I think everything will be fine. Just cable management will be a b*tch.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
sounds like a lot of work for little if any reward. as far as i am concerned, anything that a vacuum and compressed air will not remove can stay there. i tore apart my 10 year old desk top, that only got cleaned once a year, and there was very little dust behind the mobo or back in corners. its not like your driving it thru a field, or across a desert. i guess if you lived where there are dust storms, it might be a worthwhile endeavor. now a laptop, that gets used in a multitude of laces and conditions, might be a different story. i have taken 2 of them apart so far, and there was more dirt inside than i would have thought. plus they have a marginal cooling system to start. but, if you feel the need, good luck. i wish all the best.
How dusty a system gets depends on how much air is flowing into the case and the room the system is fine. For some, a years worth of dust is only as much as a few weeks for someone else.
